Hey Everyone just got back from Deployment - Ford Powerstroke Diesel Forum
The Cascade Coal Rollers Oregon and Washington members of Powerstroke.org Chapter Area
post #1 of 21 Old 12-16-2013, 06:09 PM Thread Starter
clcruce's Avatar
Garage
Hope everyone is doing good, got back from deployment on the 5th of Dec.
I decided to buy a bunch of stuff to upgrade my truck (engine and looks). I bought an Edge CTS as a monitor system (only) when I hooked it up and ran the diagnostic test I have a P0236 Turbo boost sensor A circuit performance caused by a restricted inlet/exhaust/supply hose, missing hose. Checked the red and green hose they were good but havent check the hose to the MAP sensor yet. Also maybe another subject or related to the previous one the prior owner had the 7.3v diode boost fooler installed and when I uninstalled it I only get 6 psi boost wide open,but I was looking for some inputs for that as well.
Glad to be back and hope everyone has a Merry Christmas,
Chris
Chris
E99 F350
AFE Two Stage Cold Air Intake, 5" MBRP Exhaust, Edge CTS (system monitor), PHP Hydra Chip, HPx
[/URL]
clcruce is offline
The Following User Says Thank You to clcruce For This Useful Post:
TD444EVER (12-16-2013)
post #2 of 21 Old 12-16-2013, 06:22 PM
drivininidaho's Avatar
Quoted: 81 Post(s)
:thank you2:
well Chris, first off welcome back and THANK YOU FOR YOUR SERVICE!!!!!!!!!
im one of the "new" members around here. wish i could help more on your truck but im not too familiar with the 7.3
Lyndel
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #3 of 21 Old 12-16-2013, 06:40 PM Thread Starter
clcruce's Avatar
Garage
Thank you for your support, I appreciate it.
Chris
E99 F350
[/URL]
clcruce is offline
post #4 of 21 Old 12-16-2013, 07:51 PM
JesseKK's Avatar
Quoted: 50 Post(s)
Garage
Glad you made it home safely. Thank you for your service.
JesseKFK
2007 F250 XLT CC 6.0 PowerStroke FX4 R.I.P. 3.6.16
Livewire TS LOoNeY
Studded
BPD 58v FICM
BPD Oil&Egr Cooler
Glow Shift Pyro,Fuel
High Idle Mod UF#4
Fog Light Mod
Harpoon Mod
Dome Override Mod
6000k Bi-neon Hids
Sinister Coolant Filter
8in Rize Ind 4 link
35" Mickeys on 20s
Blue Leds
Power Service Every Fill Up
ATV 2008 Yamaha Raptor 700 FI
KCCO
Originally Posted by Karls03 View Post
I hate Edge power products so much, I quit using Edge shaving gel
JesseKK is offline
The Following User Says Thank You to JesseKK For This Useful Post:
clcruce (12-16-2013)
post #5 of 21 Old 12-16-2013, 09:14 PM
i appreciate all the sacrifices you and your family made for myself and mine. I hope you enjoy your Christmas back at home.
_________________________________________
02 f350, AFE stage 2 intake, wicked wheel, edge
evolution, performance authority trans, 10" lift 38's
with 4:56's, C2 gauges, 4" turbo back AERO muffler
TD444EVER is offline
post #6 of 21 Old 12-17-2013, 05:13 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Welcome Home
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #7 of 21 Old 12-24-2013, 07:05 AM
7.34ever's Avatar
Quoted: 2 Post(s)
Feedback Score: 9 reviews
Chris
Sorry I missed your post Chris. Welcome back and thank you for your sacrifice. I think it means more to than anyone could ever express and more people should do so.
As for your boost issue, the only thing I can think of is that filter monitor that is in the air box. It can throw a code and it's possible that your air filter may be a lil dirty OR if it was dirty in the past and the code was never cleared it would still be there.
What was your boost level before the fooler was removed?
12TH Man
Live in WA or OR??? Check out these links.
7.34ever is offline
post #8 of 21 Old 12-24-2013, 07:50 AM
sagebel's Avatar
Quoted: 10 Post(s)
Welcome back Chris.
Brandon, I don't think E99 trucks have a sensor on the filter minder. My 2000 didn't have any wires going to the filter minder. If all of the lines are not plugged or leaking and there are no intercooler piping leaks it may be the MAP sensor itself.
2014 CCLB 4x4 Lariat Ultimate
sagebel is offline
post #9 of 21 Old 12-24-2013, 07:57 AM
7.34ever's Avatar
Quoted: 2 Post(s)
You may be right Scott. I've never noticed on our older trucks I guess.
What's that exhaust tube that runs up to the front of the motor with the sensor on it? I know it can cause problems. Can't remember exactly what it does. lol
12TH Man
7.34ever is offline
post #10 of 21 Old 12-24-2013, 08:04 AM
sagebel's Avatar
Quoted: 10 Post(s)
That is the Exhaust Back Pressure Sensor. Unless you mileage or performance has dropped off there is no need to mess with it. I think I cleaned mine once in 245,000 miles.
sagebel is offline
