6.0 Head Studs? - Ford Powerstroke Diesel Forum
The Cascade Coal Rollers Oregon and Washington members of Powerstroke.org Chapter Area
post #1 of 10 Old 08-08-2013, 03:56 PM Thread Starter
oregoncalfroper's Avatar
Quoted: 12 Post(s)
Send a message via AIM to oregoncalfroper
6.0 Head Studs?
A friend of mine rebuilding his motor on his 6.0 and a local performance Diesel shop is advising him to stick with the ford bolts instead of ARP head studs because of the clamping pressure they don't stretch even a little and if something fails you would rather it be a head gasket as opposed to warpage...
Is this sound advice? I told him I had never heard of anyone advising against the ARP head studs.
oregoncalfroper is offline
post #2 of 10 Old 08-08-2013, 03:59 PM
majek5's Avatar
Never heard that either. If I had mine apart, ARP's are going back in!
2006 F350 CCLB KR FX4
stock...
majek5 is offline
post #3 of 10 Old 08-08-2013, 04:09 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 111 Post(s)
Feedback Score: 7 reviews
Studs or else
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #4 of 10 Old 08-08-2013, 04:35 PM
Term3's Avatar
Quoted: 2 Post(s)
That's absolutely the most STUPID thing I've heard in a long time. If that's what that shop thinks you need to stay FAR away from them. I guess all these companies selling bigger turbos for our trucks that state "Must have head studs to run this turbo" are just as stupid?
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #5 of 10 Old 08-08-2013, 05:03 PM Thread Starter
Quoted: 12 Post(s)
What's funny is this shop is huge ebay parts seller and machine boring and everything, my jaw dropped when he told me this right before I made the post
post #6 of 10 Old 08-08-2013, 05:10 PM
usnavyad's Avatar
Feedback Score: 3 reviews
Sounds like he would love to see the truck back in to make money on the job again it's awful explanatory stud or a bolt
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #7 of 10 Old 08-08-2013, 05:10 PM
MahdeyS's Avatar
HAHAHA Run away...run far away. Pensacola Diesel is a huge parts shop, but they can't build injectors to save their own life.
01 Excursion 4x4 PSD
MahdeyS is offline
post #8 of 10 Old 08-08-2013, 09:11 PM Thread Starter
Quoted: 12 Post(s)
The guys reasoning is if you pull and ruin threads in block that the block is then done
post #9 of 10 Old 08-09-2013, 04:08 AM
Term3's Avatar
Quoted: 2 Post(s)
Can't see that happening unless the studs were installed and WAY over torqued, but that would turn them into stretched pieces of crap. Sure I've seen the odd guy run OEM head bolts with moderately high boost but more times then not it always ends in blown head gaskets. It's like Russia Roulette, it's not IF you'll blow your head off, but WHEN will you blow your head off.
Term3 is offline
post #10 of 10 Old 08-30-2013, 09:20 AM
Ford7three's Avatar
I would never put factory bolts back in, Studs for any 6.0L doing head gaskets.
Ford7three is offline
