Headlight Warning Chime - Ford Powerstroke Diesel Forum
The Cascade Coal Rollers Oregon and Washington members of Powerstroke.org Chapter Area
Old 01-27-2013, 07:21 AM
I have a 1997 F-350 7.3PS. When the headlights are pulled on and the drivers door is open, I receive no warning chime. The dome light works with the door actuator, but I receive no warning chime when I leave my headlights on. Fuses are fine. Any suggestions?
Old 01-27-2013, 07:29 AM
turn your headlights off before you get out
LOL
any other anomalies ? i think that is controlled through the GEM/BCM ?
Old 02-05-2013, 06:52 PM
He's a good guy if anyone can help him out...
ZMANN your right too....
Old 02-25-2013, 09:55 AM
LOL
There is no GEM on a 97 amigo.
My guess is someone unplugged the dinger box, its under the dash just to the left of the trans tunnel. Plug it back in and I bet it works right. If you don't want the annoying "key in ignition chime" remove the lower plastic cover on the steering column (4-5 screws) and unhook/tape up the funny single wire connector that slides in behind the ignition cylinder. I have pics of this if needed.
