HPOP Leak - Ford Powerstroke Diesel Forum
The Cascade Coal Rollers Oregon and Washington members of Powerstroke.org Chapter Area
Old 11-20-2012, 04:32 PM
HPOP Leak
Good evening everyone,
I just came back from det and noticed my HPOP is leaking at the rear, drivers side connection. I tightened it down as much as I could but it is still leaking where the nut connects into the HPOP, also the hard line is loose and I am able to wiggle it. Is there suppose to be a washer of some kind in the mix or does the connection screw right into the HPOP?
Thanks for your help.
Chris
Old 11-21-2012, 07:09 PM
If you are referring to the HPOP lines they are orings with a push lock deal. Contact Bob at Diesel Orings he has everything you need. For the nut, are you referring to one of the plugs or the tin nut IPR? IPR can be rebuilt, but I heard it sucks.
Old 12-01-2012, 05:25 PM
Rebuilt my both of my discharge fittings today, was planning on only doing one but once I got in there I thought I might as well do both. Going to let the Loctite sit over night and give her a crank in the morning. I hope she doesnt leak; also put in my cold air intake while I was at it.
