bad starting 6.0 - Ford Powerstroke Diesel Forum
The Cascade Coal Rollers Oregon and Washington members of Powerstroke.org Chapter Area
post #1 of 6 Old 01-28-2011, 10:15 PM Thread Starter
97dodge's Avatar
bad starting 6.0
my buddy has a 2004 6.0 and says when its cold it starts like crap. runs like its low on oil clangs and shack all to beat heck. but then when warm it runs just fine. what got this be?
Sean
-370 injectors, DIY intake 6637, DIY fuel system, Built auto 3 disk TC billet shafts, 40 gal tool box/aux fuel. 100 fuel plate, advanced timing, 2.5 leveled, 35 M/Ts, 5in Aussie stacks, custome DIY functional air ram hood, one ton rear suspention, and just turned over 331,000 miles!
-four courner emergency strobe lights, L.E.D. emergency underbody strobes
97dodge is offline
post #2 of 6 Old 01-28-2011, 10:55 PM
Tmoney511's Avatar
try rev-x and what type of oil does he use?
03 6.0 f250 180k, 20" XD Hoss rims, 33" tires, boost, pyro, tranny temp, fuel psi, AirdogII 165, FASS sump, Edge CTS monitor, MBRP straight piped 6" miter cut blk stacks, k&n air intake, SCT w/ Eric's extreme street/extreme x, RECON smoked side mirror turn signals, 05-07 Banks Techni-Cooler Intercooler, Pmax turbo, ARP head studs/FCDP full EGR delete/modified intake manifold, Sinister Coolant Filtration, 12k 55w HID heads/12k 35w HID fogs
Tmoney511 is offline
post #3 of 6 Old 01-29-2011, 02:06 PM
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
Could be FICM, injector stiction, or just weak batteries. It is hard to tell without codes.
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #4 of 6 Old 01-29-2011, 02:17 PM Thread Starter
97dodge's Avatar
whats ficm?
Sean
97dodge is offline
post #5 of 6 Old 01-29-2011, 02:20 PM
Don't mind me
Quoted: 3 Post(s)
It is the brain for the injectors. He could do a voltage test to rule out the FICM. If I had my laptop I could actually find you a link to the how to thread.
Josh
post #6 of 6 Old 01-29-2011, 02:26 PM Thread Starter
97dodge's Avatar
well if ya wouldnt have ruined ur laptop
Sean
97dodge is offline
