Whether you are a weekend warrior, professional contractor or a sportsman, the BedSlide was designed with you and your Ford truck in mind. This is the easiest and the best way to get the full potential from your truck's bed. Capable of holding up to 96 cubic feet (long box) and 1200 pounds of equipment, BedSlide is a perfect solution to easy, safe and convenient cargo retrieval.
Designed with a composite weatherdeck that holds up in any weather, they feature heavy duty followers and sealed ball bearings, 32" wide grab bar and moveable D-ring tie-downs. Installation is quick and easy thanks to the bolt-on design. You can easily remove bed slides when needed.
As we've mentioned before, gift season at CARiD never ends! Get FREE BEDBIN Deck Divider Limited Edition Black (a $100 value) with the purchase of any BEDSLIDE. Hurry up! Act now, this offer expires on February 28, 2017.
BedSlide™ | Truck Bed Slide Systems - CARiD.com
If you want to maximize the potential of your truck bed - BedSlide is the best choice!
