Towing a 40' jayco - Ford Powerstroke Diesel Forum
Camping/RV's Discuss camping, RV equipment and locations.
post #1 of 12 Old 11-05-2013, 11:41 PM Thread Starter
Cj Ford's Avatar
Towing a 40' jayco
I have a friend who needs to move his 40' jayco bungalow it weighs about 12,000lbs but has a tongue weight of 1,550lbs its a bumper pull not 5er he usually pulls it with a Dodge 3500HD dually but its in the shop minus a transmission
My question is do ya think its to heavy of tongue weight for a F250 single rear wheel? I do have firestone air bags and a weight distribution hitch. I know I can pull the 12000lbs its all the tongue weight hanging way out back that is my concern
I have to tow it about 50 miles, has anyone had that kinda tounge weight on a 250
1999 F250 XLT 2WD 7.3, 6 spd, South Bend Con OFE, Detroit Truetrac, Tony Wildman tunes, Autometer Boost&Pyro, AFE Stage II, 4" MBRP Exhaust, 2" Daystars, 17x9 DC1 wheels wrapped in 33x12.50 MTZ's
Chris
Cj Ford is offline
post #2 of 12 Old 11-05-2013, 11:43 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
You will be fine. Especially since you have air bags. But still take it easy around corners and make sure all tires are inflated to the proper psi. Good luck and be safe. Try and get some pics of your truck hooked up to that beast!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 12 Old 11-06-2013, 09:12 AM
jimmyv13's Avatar
Quoted: 46 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
Should be fine...pics!
2005 F250 CCSB Lariat FX4
4" MBRP Turbo Back*Sinister Coolant Filter*SRL+*'10 Tailgate*Dicad EGR delete*Premium EdFICM*Powerslot Rotors*Hawk Pads*Riffraff boots*DIY CCV*ARP's*'10 Tails*N-FAB Steps*'12 Rear Bumper*Dashboss*Pioneer DVD*'08 Trans Pan
*Bullitt y-pipe*'14 PE PF Mirrors*Fox 2.0 IFP*'08 Diff Cover
jimmyv13 is offline
post #4 of 12 Old 11-07-2013, 06:57 PM Thread Starter
Cj Ford's Avatar
i think it should be ok was hoping someone was sure it was ok cause they had done it before lol
ill get pics
Chris
Cj Ford is offline
post #5 of 12 Old 11-07-2013, 07:35 PM
HillbillyDeluxe39's Avatar
I can tell you for sure your ok with bags and a load distribution hitch because I pulled my 40' Jayco Bungalow over 200 miles last year. Stock F250 single wheel no hitch or sway control. It was a #10 pucker factor for me but you should have no problem.
Definitely take a picture, looks like a beast all hooked up.
2000 F250 CCSB 4x4
6637, Tony Wildman Tunes, HPx, Terminator HPOP, 6.0 IC, WW, 285/75R16 Hankook Dynapro AT's
HillbillyDeluxe39 is offline
post #6 of 12 Old 11-07-2013, 09:02 PM
I've pulled more, with less truck, for a longer distance. I wouldn't make a habit of it, and take it slow. That much travel trailer is a huge sail, and any passing semi will make your knuckles turn white, but you've got enough truck for it.
Gosh a Dodge in the shop for a transmission, Who'da thunk it LOL
Tommycat is offline
post #7 of 12 Old 11-07-2013, 09:24 PM Thread Starter
Cj Ford's Avatar
thats what i wanted to hear someone who did it ... a few people including the dodge dually owner said i didnt have enough truck, i would need a 350 dually ...
Chris
Cj Ford is offline
post #8 of 12 Old 11-07-2013, 09:25 PM Thread Starter
Cj Ford's Avatar
3rd tranny in 120,000 miles last 2 were supposed to be better then stock ...
Chris
Cj Ford is offline
post #9 of 12 Old 11-07-2013, 09:37 PM
Teachagmech's Avatar
Quoted: 398 Post(s)
Garage
All they said was Cummins likes to stack... Blowing huge clouds of black smoke doesn't make the transmission have a good time. But the mirrors, those are neat lookin'
Sent from a phone that makes calls too!
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #10 of 12 Old 11-08-2013, 02:18 AM
Quoted: 8 Post(s)
IMO, the 2012 dodges and older(or whenever they changed frame rails and suspension drastically) didn't compare when pulling. A 3500 DRW didn't compare to any F250 powerstroke... Yea they have better rear end stability due to the duals but the front ends on any dodge wonders and sways like crazy when a huge load is pulled. I've personally pulled the same trailer with a 97 F350 SRW and a 2003 3500 DRW and the Ford pulled it better hands down and the Ford was an E4OD and the dodge had a manual trans. There's a reason why the F-Series is the number 1 selling truck for so many years! Even the reputation of the 6.0 couldn't bring it down
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
