Rear end sag - Ford Powerstroke Diesel Forum
Camping/RV's Discuss camping, RV equipment and locations.
post #1 of 7 Old 07-21-2013, 05:05 PM Thread Starter
Ajc722's Avatar
Rear end sag
I have an issue with rear end sag. Well I don't, but my truck does. What do you guys use to keep the squat out of the rear when towing? Air bags or helper spring. I have the camper pkg but it stil squats. 750# tounge.
Ajc722 is offline
post #2 of 7 Old 07-23-2013, 05:05 AM
69Stang's Avatar
Do you have a weight distribution system? You should with a 750 lb tongue weight. I have a 1200 lb tongue weight and with my WD it only squats an inch or so.
2010 F250 Cabela's Edition FX4, 6.4L, 3.55LS.
2011 Palomino Throroughbred 828RLS travel trailer.
"Democracy is two wolves and a lamb voting to have lunch. Liberty is a well-armed lamb contesting the vote!" Benjamin Franklin
69Stang is offline
post #3 of 7 Old 07-23-2013, 06:17 AM
Have you done the proper procedure to set up your weight distribution hitch? If not that will cure your problem to a certain extent. If the rear of your truck is squatting then there is less weight on the front tires, therefore less braking from your front end.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #4 of 7 Old 07-24-2013, 06:37 AM Thread Starter
Ajc722's Avatar
I have a Hensley Arrow hitch which does have weight distribution bars. It still sags. Not a lot, but noticeable. I plan on putting a golf cart in the bed as well. Just want to keep it as even and as safe as possible.
Ajc722 is offline
post #5 of 7 Old 07-24-2013, 09:02 AM
Check this out --->http://www.equalizerhitch.com/pdf/EQOwnersManual.pdf
These are the instructions for the hitch I have but the same general setup principles apply.
Also, if you are going to haul the golf cart in the bed I would do the hitch setup with the golf cart loaded.
Blue Spring Mod
SCT Livewire ts
post #6 of 7 Old 07-24-2013, 09:05 AM
Here is a thread you can read also ---> weight distribution hitch?
Blue Spring Mod
SCT Livewire ts
post #7 of 7 Old 08-09-2013, 07:30 PM
Glow Plugs Only
dee004's Avatar
Ajc, I have Firestone air bags. The following pics are of my truck with the trailer attached and 50PSI in the air bags. As you'll see with a pin weight of 3100lbs the truck doesn't even squat to the helpers. The ride is awesome as well. The only difference being it's a fifth wheel as opposed to a rear tongue mount as yours is. Hope this helps you out...
05 F250 CCSB 4X4, 05 VW TDI
4"Banks Turbo Back, ARP Studs & OEM Gaskets,
Coolant Filter, Blue spring, Zoodad
Bypass Oil Filter, Kitty By By, Standpipes dummy plugs
BPD oil cooler, EGR Delete, CCV Mod, BPD Oil Cooler, SCT SF3
dee004 is offline
