adjustable hitch question - Ford Powerstroke Diesel Forum
Camping/RV's Discuss camping, RV equipment and locations.
post #1 of 5 Old 06-19-2013, 04:58 AM Thread Starter
Ok, I had my hitch adjusted just right but now that I throw the golf cart in the back she squats a little. So my quesiton is to get it up a little do I move up 2 bolts or do I just adjust the little block on the top bolt?
heres how she sits now. shes not hateful but Id like to get her just a bit more level.
06 F350 KR / 12 sprinter 323bhs
tomsws6 is offline
post #2 of 5 Old 06-19-2013, 05:16 AM
This is a good question. I had the same problem last time we went to the mountains, I hauled a cord of firewood and my truck was squatting like that. I believe if it were me and was going to haul the golf cart each trip you take I would do the whole hitch set up again with the golf cart in the bed of your truck. That way you will get the weight distribution correct on the front and rear tires of your truck.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #3 of 5 Old 06-19-2013, 10:48 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
If your truck is squatting, then that means that the front of your trailer is squatting the same amount, so you would want to adjust the block on the upper bolt to give the hitch more tension which would raise both the truck and trailer correctly.
If you were to just move the 2 bolts up, then the trailer would come up to level but the truck would still sit low.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #4 of 5 Old 06-19-2013, 06:05 PM Thread Starter
Yeah I thought about that. Iv moved the hitch itself up and am going to move the mounting bars on the trailer too. Thanks!
tomsws6 is offline
post #5 of 5 Old 06-19-2013, 06:08 PM
ZMANN's Avatar
Quoted: 1785 Post(s)
Airbags are perfect for this variable load situation
We Miss you Ronnie
ZMANN is online now
