Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Off-Topic > Camping/RV's
Camping/RV's Discuss camping, RV equipment and locations.
Old 03-19-2008, 05:24 PM
IanThrones IanThrones is offline
TV Booster?
I or I should we just bought a 05 Sydney outback 28frls fifth wheel and we were hanging out in it the other night and I can't get the TV to work on the antenna is there a switch or wire you have to change around from the site cable hookup to antenna I didn't get a manual with it and the only thing I could find online was to turn on the booster?? where is this located? whats it look like? the only thing I can do is start pulling panels off to trace wires but I thought I would ask here first
Old 03-19-2008, 05:36 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Should be a switch. My dads 5er has a box under the tv with a bunch of switches for different inputs such as cable, satv, ant
Old 03-19-2008, 05:39 PM
I ve looked there even took the panel off under the entertainment center and can't find nothing
Old 03-19-2008, 05:43 PM
Hmm did it come with any paperwork or manuals on the trailer to give you an idea. I would think it would come with one, but maybe not
Old 03-19-2008, 05:45 PM
CAT797 CAT797 is offline
Sparkplugs Not Required
Is the hookup on the wall labeled Antenna? I don't know but maybe there is a connection for antenna and one for cable.
Old 03-19-2008, 05:48 PM
No paper work at all only one coax plug not labeled can't find anything else at all
Old 04-24-2008, 07:45 PM
BryanH BryanH is offline
Is the ant booster in the front bedroom? If so it should be a little black button that has a green light next to it. If you find it just push it in and the light should come on. But make sure you are on AC power and not DC. It will run a battery down in an hour or so. If you do not find lt let me know. I have an 04 FW28FRLS at work, I will take a look at it Friday. Also I have seen them come from the factory not hooked up to the ant. I can get you some info or manuals if needed.
Bryan
Old 04-24-2008, 07:56 PM
Thanks I found it I think but I haven't tried it yet its on the cable cover plate in the bed room I'll take a generator out to it this weekend and try to get it to work and I will let you know Its still below freezing hear and I haven't been able to use it since I bought it and I sure am getting anxious
