axle dust cover question- - Ford Powerstroke Diesel Forum
Camping/RV's Discuss camping, RV equipment and locations.
post #1 of 4 Old 06-02-2013, 09:16 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Ok I know this is stupid and dosnt reeley matter but Im curious. I just did a total bearing/race replace and packing job on the camper. The bearing kit that I found on amazon ( that was friggin AWESOME by the way)http://www.amazon.com/gp/product/B001HXAIDS/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1 If you look at the pic of the product it shows the dust covers, the solid ones and the ones with the rubber plug type insert's. Ive never used the rubber plug type ones. Are the kinda like bearing buddies? Is it just a inspection type plug? Ever use these before??
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 4 Old 06-03-2013, 06:33 AM
I have always used the solid dust covers other than on my fourwheeler trailer I put bering buddies. First time I have ever used them and the last after what you guys told me. I believe the covers may actually be bering buddies because mine have a rubber cover over the zerk fitting. Not sure why if they are not bering buddies they would have a rubber cover though.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #3 of 4 Old 06-03-2013, 08:23 AM
ZMANN's Avatar
Quoted: 1566 Post(s)
those are for rear zerk lube applications alzso advertised as torsion bar caps on the site wher you purchased your kit
http://loadrite.com/pdf/LoadRite-Ser...ns/Torsion.pdf
i use bearing buddies because i have 3 trailers that get submerged and the bearing buddy keeps the air pocket out of the inside and prevents water from being sucked in when a hot bearing meets cool water
We Miss you Ronnie
ZMANN is offline
post #4 of 4 Old 06-03-2013, 01:39 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Thanks guys! You stopped me from lookin like a jackazz. ( I was half thinking of running these cause then I could just pop the little cover off and take a look around.....)
You saved me
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
