A trailer question - Ford Powerstroke Diesel Forum
Camping/RV's Discuss camping, RV equipment and locations.
post #1 of 8 Old 05-28-2013, 01:19 PM Thread Starter
Ajc722's Avatar
A trailer question
So I am out camping for the holiday weekend. Great time. Disney Ft Wilderness never fails. Packing up the site Monday morning I take a step into the trailer and the entire front end of the unit drops 12 inches with a loud Bang! Both of the front stabilizer jacks failed causing the front to slam down on the tounge jack. The jacks were on wood blocks sitting on a concrete slab. I get the unit hooked to the truck and headed to camping World where I bought it. I was then informed that I had overloaded the jacks and I was responsible for the replacement. the rig is a 13 heartland bought 7 months ago. So how much pressure do I put onto the stabilizer jacks? just snug? Snug plus a turn? I have been cranking them to remove some of the rock off of the suspension. Any Advise is appreciated
Ajc722 is offline
post #2 of 8 Old 05-28-2013, 01:23 PM
Were you supporting only with your stabilizer jacks or did you have your ball jack down also?
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #3 of 8 Old 05-28-2013, 01:29 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Im assuming if it dropped 12 inches the tounge jack was not being used.
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #4 of 8 Old 05-28-2013, 01:31 PM
I just reread your post. I am assuming that since the front jacks failed and you ball jack slammed down that you had it in the up position. I always level with my ball jack front to back and leave it down with weight on it. Then I put down my stabilizer jacks only to stabilize the camper not really to hold that much weight. So most of my weight is on the tires and ball jack.
Blue Spring Mod
SCT Livewire ts
post #5 of 8 Old 05-28-2013, 02:32 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Yes, the stabilizer jacks are just that - "Stabilizer Jacks", they are not meant to hold the weight of the trailer, only to keep it from rocking once you have already leveled it with blocks under the tires and by using the tongue jack.
When you use them, you can snug them up pretty good but do not let them take all the weight off of the tongue jack (the tongue jack is designed to hold the weight of the trailer).
I flattened a pair once when my tongue jack slipped off it's block when getting the trailer set up in the sand dunes
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #6 of 8 Old 05-28-2013, 04:04 PM Thread Starter
Ajc722's Avatar
The tongue jack was up. Can't remember why but it was. I had always thought you leveled out with the jacks, and the wheel blocks were just a pain. I guess I'm getting off cheap. $100 for the pair.
Ajc722 is offline
post #7 of 8 Old 05-28-2013, 04:07 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
That is only on motorhomes that have the heavy duty hydraulic type leveling jacks.
GregsSD is offline
post #8 of 8 Old 05-28-2013, 04:50 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Awesome! Glad you got it fixed!!!
Tom
Other Rides
tkobes43 is offline
