How much of a lift if pulling a 5th wheel? - Ford Powerstroke Diesel Forum
Camping/RV's Discuss camping, RV equipment and locations.
 2Likes
  • 1 Post By blb1224
  • 1 Post By Rammstein1224
post #1 of 9 Old 05-21-2013, 08:12 AM Thread Starter
Question How much of a lift if pulling a 5th wheel?
Afternoon all..
I have a 2011 F-250 6.7 Diesel. While I enjoy the truck immensely, I actually bought it to tow a 5th wheel camper. I would like to lift it a bit and put much nicer wheels and tires on it though. (I mean let's face it.. I won't always have a camper behind me right?)
Anyway, I'm unsure of how much I can raise the truck before it affects my towing and camper. Has anyone elwse out there stumbled across this dilema and if so how did you satisfy your need for a cool truck wit hthat of the family camper?
THanks in advance and hope to hear from you!
blb1224 is offline
post #2 of 9 Old 05-21-2013, 08:34 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I know i have seen guys with at least 6 inches and probably 8 inches towing 5-ers . Goosenecks are when you run into trouble with lifts because they typically have the triangle bracket support that goes right over the tail gate at will take out your bed corners but with a 5-er theres more bed clearance plus fords a$$ ends sag alot under load.
I have only pulled a flat bed with my truck and honestly it handles just like a stock truck as long as you have the right gearing pulling-wise you should be fine. Look at changing the gearing if you do end up lifting the truck AND towing with it.
And lastly make sure your tires are rated for the weight your carrying. Typically big mud tires arent rated for as much weight as towing tires so look at that when you buy tires that you buy ones that can carry the load of you AND your truck
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 9 Old 05-21-2013, 08:49 AM
Chapter Director
Quoted: 5 Post(s)
Ask this guy if you have any questions
http://www.powerstroke.org/forum/mem...jetjock15.html
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 9 Old 05-21-2013, 10:28 AM
new2deisel's Avatar
I'm not as high as some on this forum but I have no problems towing my 35' toyhauler with 35" tires and 5" lift. I've thought about 37" tires but then I would probably have to lift trailer too and don't want to do that.
new2deisel is offline
post #5 of 9 Old 05-21-2013, 01:05 PM
layson's Avatar
Quoted: 83 Post(s)
4" lifts are usually what guys do... you won't have any issues.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #6 of 9 Old 05-22-2013, 02:57 AM Thread Starter
Thank you all for the quick response. I think it's safe to say I can go with at leat a 4" inch and be pretty safe at this point.
I have owned my truck for about a year now and after seeing some of the trucks on here and the things you guys do to them, it kinda of gives you that "bug" so to speak.
Do now I need to figure out what to do with the rest of the truck. There are so many options.. But, that's for another forum.
So againi, thank you all very much for the help. Most appreciated!!
sabarnes likes this.
blb1224 is offline
post #7 of 9 Old 05-22-2013, 06:51 AM
Chapter Director
Quoted: 5 Post(s)
Oh its more of a bug its a virus or an STD that just wont go away
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #8 of 9 Old 05-28-2013, 09:39 PM
tubular031's Avatar
The more you lift the truck the more the trailer needs to go up. 5ers are usually high to start and making them higher is not a good plan. Don't forget you need a few inches between the bed and the trailer to compensate for the road/driveways/dips/twists/hills.
if you bought the truck to pull leave it alone and pull. If you want big flashy show off, get another truck. you need the right tool for the job.....
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #9 of 9 Old 05-29-2013, 07:10 AM
new2deisel's Avatar
That's kind of a bold statement. Just because he is looking to lift his truck doesn't mean he's looking for "big flashy show off". Mine is lifted but far from big or flashy. I see no need to,have 2 different vehicles when I can do everything with one. I need the ground clearance for places I like to take my truck and the wife loves the comfort of a trailer. Since I've had the trailer I can think of 3 times where I had to worry about bed clearance, 2 were from places I shouldn't have been with a trailer and here going in/out of our hunting location.
I like to,have my cake and eat it too
Tags
camper , lift
