A TT towing question. - Ford Powerstroke Diesel Forum
Camping/RV's Discuss camping, RV equipment and locations.
 3Likes
post #1 of 23 Old 05-11-2013, 07:14 PM Thread Starter
Ajc722's Avatar
Recently upgraded to a 2012 250 cc4x4 diesel. Currently tow a 34ft TT with a #7000 wgt. My 1/2 ton GMC would tow it but man did it sway... I bought the Hensley Arrow Hitch and noticed a significant difference. My question is will having a heavier truck eliminate the need for the expensive hitch? or should I just use it.
Ajc722 is offline
post #2 of 23 Old 05-11-2013, 09:38 PM
jimmyv13's Avatar
Quoted: 46 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
Might as well just use it....it's arguably the best system out there.
2005 F250 CCSB Lariat FX4
4" MBRP Turbo Back*Sinister Coolant Filter*SRL+*'10 Tailgate*Dicad EGR delete*Premium EdFICM*Powerslot Rotors*Hawk Pads*Riffraff boots*DIY CCV*ARP's*'10 Tails*N-FAB Steps*'12 Rear Bumper*Dashboss*Pioneer DVD*'08 Trans Pan
*Bullitt y-pipe*'14 PE PF Mirrors*Fox 2.0 IFP*'08 Diff Cover
jimmyv13 is offline
post #3 of 23 Old 05-13-2013, 06:01 AM
Sounds like your Hensley Arrow Hitch has some type of sway control built in. That being said I doubt you will need to worry about the tt swaying when towing. I use a Equalizer hitch, we left out a couple weeks ago in some serious wind and we had no problems what so ever with sway. You will see a world of difference pulling with your new 6.7 vs the gmc.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #4 of 23 Old 06-17-2014, 07:22 AM
We are seriously considering trading our F150 EcoBoost in for a 250 diesel to tow our 8000# TT. Looking for any and all suggestions, advice, comments. This post was very encouraging
Likes2camp is offline
post #5 of 23 Old 06-17-2014, 07:23 AM
Forgot to mention we have the ProPride no sway hitch, kissing cousin to Hensley.
post #6 of 23 Old 06-17-2014, 09:18 AM
Have you tried pulling your tt with the eco boost yet? Wondering how well it towed if you have. For me pulling my 8k tt with my truck is no problem what so ever. You won't regret getting a diesel to pull your tt, actually that's all I ever pull. Good luck in your decision and keep up posted.
Blue Spring Mod
SCT Livewire ts
post #7 of 23 Old 06-17-2014, 05:16 PM
We have taken several trips pulling ourTT with our EcoBoost. Coming home from dealer on day of purchase when we experienced lots of sway with our Eaz Lift hitch. Next traveling about 50 miles with tighter adjustment to Eaz Life. Better but still sway and 100 lbs light on steer wheels. Nectar same 50 mile trip with new ProPride...NO sway, but truck wandered in lane...even lighter on steer wheels. Adjusted ProPride drove up local mountain pass, no sway buts lots of wandering in lane and husband/driver felt TT was pushing truck around. Weighed at scales on way home, now steer wheels almost 300 lbs light and rear axle almost maxed out at 1300+ lbs. ugh! The EcoBoost has pulling power, but we can't get wt distributed right and feel very unstable. Don't want to spend $ on 250, the EcoBoost is a 2013 with 10,000 miles on it, but don't feel safe towing (yet? we still R hoping we can figure this out).
post #8 of 23 Old 06-17-2014, 05:54 PM
sagebel's Avatar
Quoted: 8 Post(s)
If you are within all of your weight limits, not getting pushed around by the trailer, and not having a hard time pulling grades then you don't need a new truck.
2012 F350 DRW King Ranch FX4
Originally Posted by nighthawk285 View Post
Pull it sideways back and forth....and don't be gentle
Originally Posted by Six0~Stroker View Post
I was just planning on running over here and whipping it out. Sent from
sagebel is offline
post #9 of 23 Old 06-18-2014, 06:11 AM
Sounds like your weight distribution hitch is not set up properly. You should have pretty much the same weight on the front wheels as normal. I went through how to properly setting up the wdh in another thread in the camping section. After trial and error I have my truck pulling really good. With proper setup of the wdh you will take some of the rear axle weight and move it to the front. Check out this link, I know its not your hitch but the setup instructions will be the same http://www.equalizerhitch.com/pdf/EQOwnersManual.pdf
Blue Spring Mod
SCT Livewire ts
post #10 of 23 Old 06-18-2014, 06:39 PM
Very helpful information in your post. Thank you. We will use the info in link tomorrow and see if we can get the balance we need. I thought the measurements of front fender drop to be most helpful. I was focused solely on back wheel fender drop. An ah ha moment. Thanks for your help.
