Travel Trailer/ Camper advice - Ford Powerstroke Diesel Forum
Camping/RV's Discuss camping, RV equipment and locations.
post #1 of 52 Old 09-27-2011, 05:11 PM Thread Starter
semperfidoordie's Avatar
Looking for advice on a travel trailer or camper. Never purchased one before and as the time to move to 29 palms nears im wanting to find one so we will have stuff to do out there rather than smoke/cook crank and drink ourselves to death. Want something decently priced (under 10k) with decent amenities. Thanks guys
2006 F-350 King Ranch CCSB 4x4
Scangauge II
USMC/OIF Veteran
2005-2014
semperfidoordie is offline
post #2 of 52 Old 09-27-2011, 06:03 PM
billieg's Avatar
Go on Creaigslist and find one. What ever price they are asking deduct 20%. Just make sure everything works and the floor is solid and the tires are no older than 5 years...
2007 F-350 dually/diesel, Banks inter cooler, High rise intake and down tube, EGR delete, Turbo back 5" exhaust, Blue spring, 6.4 banjo bolts, coolant filter, Scan gauge II. Pulling a 40' tri axle 5th wheel toy hauler with a custom Harley in it. 70' overall
billieg is offline
post #3 of 52 Old 09-27-2011, 06:24 PM
MDarrough's Avatar
Quoted: 2 Post(s)
Good advice!!
Also, be sure to climb up on the roof and look it over real close for leaks, tears, etc.
Happy camping!!
Mark
2011 F-350 4X4 Dually Lariat pulling a 2010 Sierra 355QBQ 5er --
MDarrough is offline
post #4 of 52 Old 09-27-2011, 06:28 PM Thread Starter
Cool...is my price reasonable for a nice sized TT? Just me, the Mrs and a dog. What size should I look for?
Scangauge II
USMC/OIF Veteran
2005-2014
post #5 of 52 Old 09-28-2011, 03:43 AM
mudfuel06's Avatar
Look for something with a slide!! It's amazing how much extra room they give you. I just picked up a 93 Dutchmen that needs a little work for $2500 off of Craigslist. It's a 32' 5'er with one slide. Something in the range of 28-32 feet should work out great for you.
2007 F250 Lariat Outlaw Edition-High Idle Mod,Sinister Coolant Filter
2001 Coachmen Royal 326RLS
2010 EB Expedition EL-The Wifey's
mudfuel06 is offline
post #6 of 52 Old 09-28-2011, 06:59 AM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Feedback Score: 4 reviews
Size is a personal preference, but look for something that you won't feel claustrophobic in after a few days. A slide REALLY helps open up the floor space, but also bear in mind that it can increase your weight considerably as some of the super slides can weigh 1,500 lbs or more. Just something to bear in mind.
Double check the roof as Mark suggests, especially for trailers that are over 10 years old since they may have seen quite a bit of sun and the UV could have damaged the rubber membrane. Also, it helps if you are handy since I would estimate that the majority of trailers will have problems and they are quite spendy to have fixed by a professional. There are quite a few forums for RV's that can help you in those areas if you should need specialized help.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #7 of 52 Old 09-28-2011, 06:12 PM
Like Shawn said,leaks are a big problem.
Check inside all cabinets and closets,push up against walls and ceilings to check for firmness...if squishy,a leak has occurred....
That will give you a good insight to how one is priced and how far you want to go with it
Don't buy a money-pit
Check everywhere...lot's of scammers out there!
"Good Condition" is a major opinion of good or bad.
I looked at several excellent condition ones and WHEW!!! GROSS!!!
Hope this helps!
icysmooth is offline
post #8 of 52 Old 09-29-2011, 04:44 AM
billieg's Avatar
You want at least 1 slide or when you get stuck in it for a few days with the wife, one of ya won't walk out alive... Also, make SURE they have had the fridge plugged in for a few hours (it takes 8 to really cool down) so you know it works. They cost $1,200 new and the hot water on as well.
billieg is offline
post #9 of 52 Old 09-29-2011, 06:02 AM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
LOTS of good advice in this thread and I thought about a few more. Also pull out the awning and ensure there's no rips or tears. Crawl underneath and check the condition of the holding tanks. Go to a RV station and operate the waste valves to ensure smooth operation with no leak (That also gives you an opportunity to learn how to hook up the hoses, the purpose of the rock on your drain line AT the sewage hole, etc etc.) If you don't have a rock to hold your hose in place, you can develop enough pressure from the waste water that it will actually blow itself out of the hole and you will have a HUGE mess. There was a thread on here about somebody's first time and it wasn't pretty.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #10 of 52 Old 09-29-2011, 07:37 AM
You should be able to get a nice one around 10 K. We just bought a New 26ft. Keystone Sprinter with One big slideout and it really makes a big difference in room. Ours was around 30 K but we just wanted a new one. we have had it a couple months and used it about 6 times. I keep it spottless, and Im sure you will find one that the owner takes care of also. Its just Me my wife and our Lab. Still plenty of room.
Richard
2011 F-250 Super Duty 6.7 Diesel Lariat Short bed 4x4
Last edited by Freebirdusa; 09-29-2011 at 07:40 AM. Reason: adding comment and Picture
Freebirdusa is offline
