largest cabover truck camper in a short bed - Ford Powerstroke Diesel Forum
Camping/RV's Discuss camping, RV equipment and locations.
post #1 of 3 Old 09-07-2011, 06:18 PM Thread Starter
Hey there, how is everyone?
Alright I intend to go from CO to Northern CA, to vancouver, to NY, to the FL Keys, then back to CO
We will be leaving Thanksgiving week and returning who knows when, mid Jan for now.
I have an 08 f-350 SRW Shortbed, I would like to find the largest possible (for obvious reasons) slide in truck camper, I would prefer a slide out as it has more room, I will need 4 season capability
Does anyone have and good suggestions? I would like something that is designed for a shortbed so it doesn't look all griswoldy and simply to ensure I am not over some sort of weight or size limitation
Maybe some other feedback or experience like "I had this...., it was way to big for the truck and was difficult to drive"
Thanks
chinaman is offline
post #2 of 3 Old 09-08-2011, 07:05 PM
Quoted: 58 Post(s)
Thanks
In a nutshell, almost any TC will put you at or above the manufacturers limits for a SRW truck. They are all heavy - - - and heavier than the manufacturer's sticker indicates. Most certainly any TC with a slideout will be at the upper, upper limits for a SRW truck, and will be well over the manufacturers specs for one or more of the trucks components.
You need to carefully understand your trucks limitations. For example, what is the load rating of your tires, wheels, rear axle, etc.? Think to yourself "what's the weakest link in the chain" and that's what you're limited by.
I carry a 2005 Lance 845 on a 2006 F250, SB, CC, Powerstroke, 4x4. It is HEAVY. Recent weighing on the way to a camping spot put the total at 11,400LBs. 4,800LBs on the front axle and 6,600LBs on the rear. Thats the truck with 3/4 tank of diesel, the camper, two people, 29 gallons of fresh water, and empty holding tanks. Assuming approximately 7,700LBs for the truck, driver, and one passenger, that puts the camper at approximately 3,700LBs. And yet the "as configured" weight is listed as 2,730LBs
My truck didn't come with the Camper Package (since it has the 20" wheels), so I had to add a rear sway bar. I also had to add rear air bags since I didn't have the rear helper springs. In order to carry the camper with the most stability I had to inflate the air bags to 95 PSI (of the rated 100 PSI capacity). Recently I added dual rear factory helper springs and upgraded my coil springs to 7,000LB F550 coils. I also added the Tork Lift Stable Loads which put even more of the Camper load on the helper springs. This allows me to now run about 50 PSI in the air bags.
Truck handles it well, and I spend a lot of time off road with it. But again, it's heavy. I would not go any larger without switching to a DRW.
If you haven't already, suggest you check out this website:
RV.Net Open Roads Forum: Truck Campers
Good Luck
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 3 Old 08-10-2014, 04:36 PM
Send a message via Skype™ to bikepsych
I have a 2013 F250 SRW short bed and am using a 2013 Adventurer 89RB. So far I love the versatility of the combination. Am looking forward to four season camping in it in places that would be too cold for regular camping. I added the SuperSway Stops and they helped a lot. I'm also adding a Helwig Sway Bar when it shows up as it sways just a bit on tighter roads. Give me a shout if you have any questions.
bikepsych is offline
