Trailer Reverse lights - Ford Powerstroke Diesel Forum
Camping/RV's Discuss camping, RV equipment and locations.
post #1 of 7 Old 06-16-2011, 04:52 PM Thread Starter
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
What have you done for reverse lights on your trailer? We bought some cheap lights and the do not throw enough light. I need the light behind me because I back mine without a spotter at night a lot. It is hard in most campgrounds because they are not well lit. So what have you done to make it brighter back there?
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #2 of 7 Old 06-16-2011, 07:45 PM
I always get in before dark....but I would love some great ideas just in case
icysmooth is offline
post #3 of 7 Old 06-16-2011, 07:57 PM
Slacker
Evil Eye's Avatar
Quoted: 207 Post(s)
Feedback Score: 4 reviews
I'm the same and try to get in before dark.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 7 Old 06-21-2011, 10:29 AM
mudfuel06's Avatar
On my old trailer, I put the round 5" (Ithink) lights that you can buy at NAPA and wired them to the trailer battery. I put a switch in the underneath storage area and would flip them on or off when I needed them. My new trailer already has them installed. Two or three of them should work great for you at night and they are fairly cheap to setup.
2007 F250 Lariat Outlaw Edition-High Idle Mod,Sinister Coolant Filter
2001 Coachmen Royal 326RLS
2010 EB Expedition EL-The Wifey's
mudfuel06 is offline
post #5 of 7 Old 06-21-2011, 12:07 PM
johnnyroastbeef's Avatar
that's a really good idea, i didn't know i needed this mod until i read this thread! thanks.
NEW TRUCK!!: 2009 F350 Lariat CC Shortbed, 2.5" leveling kit, 35x12.5 R20 Toyo Mud Terrains,
-STOLEN 8/26/10!!!
2006 F350 CC shortbed, 2.5" leveling kit, 295/65/R20 Nitto Trail Grappler M/T's-STOLEN 8/26/10!!!
johnnyroastbeef is offline
post #6 of 7 Old 06-21-2011, 12:37 PM
Retired Coastie
I've got 2 spots on the back of my toyhauler. They're there to provide light in the back when you're loading and unloading the toys, but I use them when I'm backing at night and need light. Shouldn't be hard to install a couple and wire them to the 12v system.
MikeThompson is offline
post #7 of 7 Old 09-04-2011, 09:46 AM
jesilvas's Avatar
Quoted: 2 Post(s)
I got two 3x5 lights from tractor supply and ran a reverse wire to the trailer plug. I got the flood light style version and mounted them with a piece of angle iron bolted with a u bolt to the receiver on the back of the trailer. I set them so the left light points to the right and the right to the left. They are bright.
4R100, 2wd
330,000 + miles
jesilvas is offline
