mounting a flat screen - Ford Powerstroke Diesel Forum
Camping/RV's Discuss camping, RV equipment and locations.
post #1 of 20 Old 03-18-2011, 08:53 AM Thread Starter
bucwheat's Avatar
Hey guys I just bought a 19" flat screen and an extending wallmount for it,My question is are the studs in the corner of a wall 2" or 2x4" ?What I'm tring to describe is where two walls meet in a corner.this is what I intend to mount in the corner
1997 F-350 CC Dually
Power Hungry performance chip. DIY air intake ,4" Diamond Eye exhaust, Trans temp gauge,Pyrometer gauge
10,000 Lb. Warn Winch, 1 million candle power auxilary lights,black heavy diamond plate bumper/brushguard
bucwheat is offline
post #2 of 20 Old 03-18-2011, 07:27 PM
That's a good question,my tv half died at the end of fall,so I need to upgrade too.
I don't know this for sure,but I would think being a camper,probably 1 1/2 studs when I look at window thickness VS. wall.
Mine has a big hole where the tv was,so I bought a 2x4 ft. piece of flat oak plywood,a long hinge,and two drop pin lock hasps to make a new mount.
That way,I can open the old box.
I'm only going to use a standard mount,then feed all cables from old box to new tv,then use box for storage,I'll let you know if it works!
icysmooth is offline
post #3 of 20 Old 03-21-2011, 06:41 AM Thread Starter
bucwheat's Avatar
Yea,I knew the walls are 2" but was wondering about where two walls meet in a corner,I am thinking about maybe putting the TV mount on a piece of hardwood that would span the distance between two studs,And maybe that would be pretty strong,the Tv does not way the much but you never know about leaving it mounted in travel.
bucwheat is offline
post #4 of 20 Old 03-21-2011, 07:11 PM
That should work ok.
I'm going to mount a strap for transport to make sure it stays put though
post #5 of 20 Old 03-21-2011, 07:40 PM
WD40's Avatar
Quoted: 40 Post(s)
In my fifth wheel I mounted a 2x6 between 2 studs and used the same mount you are showing and it's worked great for 4 years now and about 30,000 miles. I took a swim noodle and split it, and place one 8 or 12 in piece on each side and under the lower part of the TV and use a strap to hold everything in place.
Good Luck
Doug
2006 Ford F-350 Crew Cab Lariat 4X2 PSD 6.0 TorqShift Automatic Transmission. Upfitter Switchers Chrome Door Handles,
Oxford White with lower part being Arizona Beige Metallic.
Creative Coating Sprayed in bed liner.
20K Reese 5th wheel hitch.
Mods. 4in. Silverline stainless steel exhaust
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
Is it time to go camping?
EX-USN
Doug
WD40 is offline
post #6 of 20 Old 03-22-2011, 04:47 AM Thread Starter
bucwheat's Avatar
Was a 2x6 wide enough for the tv mount?
bucwheat is offline
post #7 of 20 Old 03-22-2011, 06:49 AM
WD40's Avatar
Quoted: 40 Post(s)
Yes
Doug
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
EX-USN
Doug
WD40 is offline
post #8 of 20 Old 03-22-2011, 07:09 AM
Slacker
Evil Eye's Avatar
Quoted: 233 Post(s)
Feedback Score: 4 reviews
FYI, the wood framing on an RV is 2x3, so it is effectively a 1.5" x 2.5" board. Always mount into a stud and your idea to use a cross brace would work well, too. As Doug has suggested, figure out a way to ensure it doesn't have a way to move while the coach is in transit. Even the little lock nuts that are supposed to hold the TV steady aren't designed to hold it in place while the vehicle is moving.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #9 of 20 Old 03-22-2011, 11:11 AM Thread Starter
bucwheat's Avatar
Yea I had been tring to figure a way to dismount it easily when in transit,thought about looking for some wingnut type screws if there is such an animal to reattach the Tv to the mount.
bucwheat is offline
post #10 of 20 Old 03-22-2011, 11:38 AM
I know the mount we have on our flat screen has 2 knobs on the bracket that mounts to the tv that tighten down onto the bracket that mounts into the wall, so if you undo those 2 knobs you can lift the tv off the wall bracket and leave the other piece on the attached to the tv if that makes any sense to you... It was made so you could adjust the tv once you got it on the mount but would work for making it easy to travel with it
Jason, But you can call me Sir!!!
2001 F-350 CC Dually~Built and tuned by PHP~572/1161ft lbs fuel only~few LEDs here and there
GOPOWERHUNGRY.COM
Lowdown89 is offline
