Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Off-Topic > Camping/RV's
Camping/RV's Discuss camping, RV equipment and locations.
  #21 (permalink)
Old 10-07-2007, 05:25 AM
720Deere 720Deere is offline
Rule of thumb is at least 6" and preferrably 8". I have about 7" clearance on mine and have made contact with the rear of the truck backing the trailer up over a grade change.
  #22 (permalink)
Old 10-07-2007, 05:38 AM
DFurman DFurman is offline
Yeah
id never get 6". I dont want to flip my axle either but i guess i better think about it.
Doug
  #23 (permalink)
Old 10-07-2007, 05:44 AM
Doug
Or be very careful!!
  #24 (permalink)
Old 10-07-2007, 10:45 AM
forddieseltweek forddieseltweek is offline
That is the only correct way to do it.....Just remember it will be a little more top heavy.... It will work. You cant use a block because the spring is under the axle..
  #25 (permalink)
Old 10-08-2007, 03:54 AM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
We had this discussion in my suspension thread on the truck -- appears I have the camper package which makes my rear end stiff as hell!!!
Anthony -- what sorta labor does a shop generally charge to flip the axles... b/c there is no way in hell I can do it myself
  #26 (permalink)
Old 10-08-2007, 06:55 AM
I can do it in about 3.5hrs..... It is really no big deals....
  #27 (permalink)
Old 10-08-2007, 07:10 AM
Tournaments Won: 1
yah, but how much does it cost for a normal shop to do it? I don't know how or have the equip to weld and am curious what price range I'm looking at to get this done
  #28 (permalink)
Old 10-08-2007, 08:33 AM
$65hr and around 4hrs.
Plus -/+ $75 for parts....
Around $345
  #29 (permalink)
Old 10-08-2007, 08:38 AM
Tournaments Won: 1
hrmm...thats not as bad as I thought it would be.... hrmmm
  #30 (permalink)
Old 10-08-2007, 09:07 AM
Heat Heat is offline
I couldn't see what your axles looked like in the picture but if they're like mine it wouldn't make a bit of difference flipping them... Mine are essentially round tubes so there would be no difference either way they were turned... It does have welded in beams as blocks to have it ride at an appropriate hight for 4x4 trucks... See what a dealer will tell you about raising it or other adjustments that can be made... I have at least 7 or 8 inches of clearance between the bottom of the trailer and the top of the bed of my truck... It's nice to know I don't have to worry about crunching my bed or trailer for sure...
Ken....
