How long will frig n electric last on battery - Ford Powerstroke Diesel Forum
Camping/RV's Discuss camping, RV equipment and locations.
post #1 of 30 Old 07-11-2010, 04:09 PM Thread Starter
only, my frig is set up will run on 110, my gen r battery power, question is if left unplugged n did not turn the battery disconnect, how long before the batteries would be done n could not start the gen to power up everything, am going to a bike rally wednesday to set up, gen will be goin all nite, thurs morn bout 5:30am have to leave to go to work the next 2 days, so will not be back till approx 5pm on friday, should i just turn the battery disconnect when i leave thurs? some perishable stuff in frig but kept last yr, set up a dual battery last week though, but 1st batt is gettin old so not as strong any more.
fourx4forfun is offline
post #2 of 30 Old 07-11-2010, 04:16 PM
diablos30's Avatar
Quoted: 31 Post(s)
mine only lasted a few hours. if yours has the option to run on propane thats what i would do.
diablos30 is offline
post #3 of 30 Old 07-11-2010, 04:37 PM
HOUTX01X's Avatar
Quoted: 4 Post(s)
propane for sure it'll last longer...
'11 F250 KR
XRT Pro, H&S SX-E turbo kit, NoLimit intake/intercooler
OUO bars/blocks
-EGR,CCV,1993pf
Leveled w/ 35 atII
HOUTX01X is offline
post #4 of 30 Old 07-12-2010, 02:09 PM Thread Starter
so, how do u get it on to the propane, tried that last yr, stuff was just cool upon returning 2 days later, of course turn on the propane, i checked everything, readout on the frig to automatic, n killed the gen.
post #5 of 30 Old 05-13-2011, 11:08 AM
on my two 60 lb tanks i can go camping for 2 weeks with fridge running off propane and no power just water hook up. also cooking 3 times a day. and your fridge should have a knob under it or beside just turn it to propane. and my sparker doesnt work so all i do is go outside to other side of fridge and pull cap off where pilot light is supposed to be and light it myself while someone is pushing the ignite button inside the trailer.
robmoore11 is offline
post #6 of 30 Old 05-16-2011, 03:44 AM
fourx, shut off the gas at the bottle, remove the gas tube for the refrig and spray some choke cleaner into the orifice. If cleaner does not immediately start dripping out you have found the problem, just stand the tube upright and let the choke cleaner sit for as long as it takes to dissolve the crud in the orifice; if it is really plugged up and the cleaner does not work you may have to use a very small drill to poke the crud away but you do have to be very careful to not enlarge the hole. Put it all back together, and be sure to soap the connection after you turn the gas back on, hopefully this is all the problem is. Should the refrigerator still not get cold try selecting -gas- on the panel and see if that is the problem.
In every rv we have had either cleaning or manually selecting gas was the fix-hope yours is the same, as yours gets cold on battery my money is that the fix is simple.
thomas1 is offline
post #7 of 30 Old 09-16-2011, 05:13 PM
Dry ice. a few lbs will keep everything good and cool for a couple days.
HAM_RADIO_MAN is offline
post #8 of 30 Old 12-11-2011, 10:05 AM
7.34ever's Avatar
Quoted: 2 Post(s)
Feedback Score: 9 reviews
Cruisin around the forum and saw this thread. Any of you runnin 6v batteries? I have 4 of em in my 40foot 5er. 2 of the 6v batteries run in series to make 12v is said to be like havin 4 - 12v batteries. My trailer will go 2 days on those batteries and still start the gen even with the furnace runnin.
12TH Man
Live in WA or OR??? Check out these links.
7.34ever is offline
post #9 of 30 Old 12-11-2011, 10:17 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Have a trailer in the shop like that. He has 4 also. It's a New Horizon. Two pair of 6V in a parallel series. It seemed pretty powerful but his needed cleaning badly and the wiring could've been done better. Not too many like that though.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 30 Old 12-11-2011, 10:44 AM
7.34ever's Avatar
Quoted: 2 Post(s)
It's absolutely the best setup ever. The power is amazing and the 6v batteries hold a charge really well in series like that.
I converted my own cause it seems like the dealer just wants to get ya out the door fast rather than doin it right.
12TH Man
7.34ever is offline
