00' 7.3 O/D problems and more HA - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-16-2009, 12:18 PM Thread Starter
Exclamation 00' 7.3 O/D problems and more HA
ok Check it out cali strokers, my 2000 F250's o/d switch is not working. the light is off or either burnt out. and my truck drives as if o/d is off. which is terrible in city driving, its sapping my gas mileage like crazy and my tranny longevity probably HA! I need to know or figure out how to go about fixing this problem. Also, this just started last night, my truck developed a rough idle and it almost sounds like its loping... idk. Some one should steer me in the right direction here. 177k miles on it.
6" lift on 35"s w/17" eagle Alloys
4" turbo back w/6" tip
Pretty Much Stock =]
PoWeR StRoKe IT is offline
post #2 of 6 Old 06-16-2009, 12:30 PM
Thrill Seeker's Avatar
I had the same similar issue. Ended up being some wet soaked sensors on both sides of the trans and having to replace a solenoid in the trans to fix the issue. It's worked great since.
8" Lift
38" Toyo MT's
DIY Traction Bars
Zoodad-AIH Delete-Foil Delete
Adjust. Wastegate
ISSIPRO Performax Gauges
4" TB Magnaflow Exhaust w/ 5" tip
AFE stage 2 PG 7 W/Pre-Filter
Superchips Prgmr 150HP/225TQ
Oil X-over Line
Smoked Lights w/LEDs & HIDs
DIY 3 stage Water/Meth
CCV
6.0 IC
Transgo Shift Kit
Derale Trans. Frame Rail Cooler
Thrill Seeker is offline
post #3 of 6 Old 06-16-2009, 01:17 PM Thread Starter
ohhhh ok. was it something you did yourself or did you have to take it down to a shop?
post #4 of 6 Old 06-16-2009, 01:21 PM
I installed it my self, took a couple hours to do that and flush trans and oil so shouldn't take you too long.
8" Lift
38" Toyo MT's
DIY Traction Bars
Adjust. Wastegate
Oil X-over Line
CCV
6.0 IC
Transgo Shift Kit
post #5 of 6 Old 06-16-2009, 01:50 PM Thread Starter
oh ok cool thanks
post #6 of 6 Old 06-16-2009, 01:58 PM
You're welcome.
8" Lift
38" Toyo MT's
DIY Traction Bars
Adjust. Wastegate
Oil X-over Line
CCV
6.0 IC
Transgo Shift Kit
