Exaust (CAT) question for the Cali folk - Ford Powerstroke Diesel Forum
Old 07-30-2011, 02:51 PM
So this morning I installed my Mbrp 4" turbo back. It's the kit the re-uses the CAT.
The sound is pretty good, and my egt's did drop a little. About 75-100*. With the kit I also ordered the CAT test pipe. I didn't put it on because I'm a little worried about having it on abd getting poped with it some how.
My question is how many of you are running without CAT's? Is it worth the trouble? I would really like to run it with out the CAT I'm just a little unsure.
Old 07-30-2011, 07:55 PM
Location: Northern CA, half way between Redding & Sacramento
You'll need the cat installed when you go in for your silly diesel smog test. Once you've passed the smog, take the cat out and put your test pipe in. Reverse procedure in two years when it is time for the smog test again.
Old 08-05-2011, 03:48 PM
I'm cat less, 1997 isn't required here and I keep my truck registered in Ga
