edge or SCT??? - Ford Powerstroke Diesel Forum
Buckeye Powerstrokes Ohio Chapter of the ORG.
post #1 of 4 Old 01-06-2012, 07:09 PM Thread Starter
Motorboy8769's Avatar
edge or SCT???
i want to buy a tuner id like to go with sct but i need a monitor as well. i was looking at the edge cts as a monitor. i am debating looking to be cost effective should i just go with sct live wire? will it monitor the things i need it too or the same as the edge? or should i go with the edge monitor and tunes from edge as well? i have also seen some people use a "scan guage II" to monitor.... any info would be great dont want to spend an arm and a leg on the tuner and monitor so i can do the other needed things for a 6.0. also it is not studded and stock EGR for now.
or any for sale used would be an option as well. let me know. you can email me also if it is easier. blileracing8769@yahoo.com
Troy
2008 f-350 CCLB,
Rough country 4.5" radius arm drop lift
doc and Dpf delete
looney street from vivian
Motorboy8769 is offline
post #2 of 4 Old 01-07-2012, 08:35 AM
Stay away from edge for tunes. Get a sct with custom tunes and a cts to watch every thing. It's costly but well worth it.
this is wallie (grey truck)04 ccsb 6.0 4x4 f250 8 inch lift 38s edge insight cts,sct sf3,egr delete,cat delete,warren 175s,arp studs,oem head gaskets , stock turbo .s&b intake,4" mbrp straight pipe. (Red truck) this is Eva 01 ccsb 4x4 f250 5.4 6 inch lift 33" tires super turd lol
92f150300six is offline
post #3 of 4 Old 01-07-2012, 09:44 AM
97bluepowerstroke's Avatar
Yes and if you are going to get a SCT.. your gona need egr delete and studs unless you baby it.
97 f250hd 4x4 7.3l. TW 6 pos, Rosewood Stage 1 Injectors, gauges, DIY intake, 3in dp ti 5in exhaust, D66 turbo.. More to come
97bluepowerstroke is offline
post #4 of 4 Old 01-07-2012, 01:08 PM
Egr delete and studs should be on every 6.0 list
