Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Body 911
Old 04-20-2009, 08:50 AM
Thumper1974 Thumper1974 is offline
Can't open my hood! PLEAE HELP!
I accedentally unhooked my latch to pop the heed open from the cab, now I can't get under the hood.
Has anyone done this before, and know a way to get at the latch with the hood down?
Thanks in advance!
Old 04-20-2009, 08:55 AM
jhaddox jhaddox is offline
Send a message via AIM to jhaddox
just try to find the wire from the bottom of the engine or something...it has to go through the firewall somewhere..when you find it just pull it and it will pop open
Old 04-20-2009, 08:56 AM
jesilvas jesilvas is offline
yea find that cable and pull it with some pliers or something
Old 04-22-2009, 04:59 AM
Can't open my hood
I can" do that becouse the cable is not hooked up to the lach.if the cable was just broken i could see that working. thanks but i still need help lol.
Old 04-22-2009, 05:44 AM
i don't get what you're saying then. which latch is it not hooked up to? the hood latch or the one in the cab?
Old 04-22-2009, 07:43 AM
Powerage Powerage is offline
I think he means the cable from the handle in the cab is dissconnected from the latch inder the hood.
If that's the case then get a thin screwdriver or something like that. You'll probably need a flashlight too. Stick it in between the grill and hood and push the latch over with that!! If you can see it.
Old 04-22-2009, 03:20 PM
yes i had to take my rad out to get repaired to do that i had to diconted my cable from the lach under my hood i forgot to rehook it up and i closed my hood now when i pole the handle it don't work lol sorry i am new at this. so the cable is unhooked from the lach under the hood. i have a 2008 f350 sd and not shure how to get my hood open.
Old 04-24-2009, 04:51 AM
the lach is behind the rad on the 2008 f350 sd
Old 04-24-2009, 05:49 AM
man i wish i could help you but i don't have a clue. guess you can't take the grill off. MAYBE fish it open from underneath?
or the screw driver or flat piece of metal from the front
Old 04-24-2009, 05:55 AM
RRonning1984 RRonning1984 is offline
Heavy Equipment 911
Wow that sucks. I hope ya get it figured out but I dont have any ideas!
