Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Body 911
Old 03-17-2009, 06:18 PM
G&G G&G is offline
Brakelights out and turn signals/hazards stop blinking
The title pretty much summed it up. I took my 02 F-450 and had the dump sandblasted and painted last week. On the way home after picking it up I noticed that the turn signal stopped blinking but stayed on. Turns out that both of them will do this and the hazards do this too. Sometimes when I restart the ignition it will blink for a bit but then the same thing happens. So during this I hooked up my trailer and checked those lights. Thats when I noticed the brake lights were out. I unplugged the trailer from the truck and yep the brake lights are out.
I would automatically go to the ground then check the brake switch (but would the switch mess with the turn signals?) and then the fuses (since the signals are intermittent)
And I dont have a wiring diagram or fuse box layout (dough!)
Any help-insight would be greatly appreciated
Old 03-17-2009, 06:27 PM
19558077 19558077 is offline
the ih trucks brake lights work through the turn signal switch, not sure on a f450 but heres a
Old 04-19-2009, 02:50 AM
AgentAustin AgentAustin is offline
Send a message via ICQ to AgentAustin Send a message via AIM to AgentAustin Send a message via MSN to AgentAustin Send a message via Yahoo to AgentAustin
If you need a fuse box diagram, I have the PDF file for the 2002 F250-F550 manual. I'll email it to you if your interested.
