Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Body 911
Old 12-27-2008, 07:59 PM
Will71 Will71 is offline
'94 250.. funky light issues
I just had the lights working that morning. Changed the brake line that runs from front to back along the frame.. after that, no lights. weird part is, even the front markers don't work. only lights I get when I turn them on, is headlights.
No dash Lights, no markers, no blinkers, but my 4-ways work. brakes lights work.
I have checked EVERYTHING from bulbs to every fuse on the truck, under dash fuses, power dist. box, wires running to the tails. all the bulbs. I couldnt find Anything that should be causing this. My boss says he believes it could be the actual headlight switch. but to my knowledge, I checked everything.. but any ideas, throw em this way.
Old 12-27-2008, 08:02 PM
strokerguy strokerguy is offline
not shure but heres a
Old 01-02-2009, 06:59 PM
solved the issue.. somehow, inside the headlight switch. I guess it got hot, and the plastic got warped and it seems that made a bad connection. So I say that's a good place for anyone to start if all else seems fine and you cant figure it out.
Old 02-20-2009, 02:30 AM
6point0damn2004 6point0damn2004 is offline
<---- BAD @$$ !!!
i'm gonna check that tomorrow
