cut unknown wires - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-14-2014, 08:05 PM Thread Starter
cut unknown wires
i have an 02 ford excursion and i was trying to run my CB antenna cable through the firewall and the top bundle of wires i ripped 3 of the wires. it is the largest of the 3 next to the ECM connection. what does that bundle control? it looks like it goes to the guage cluster. any help and or a wiring diagram so i can see what i damaged would be great
greasemykey is offline
post #2 of 7 Old 05-14-2014, 08:12 PM
ZMANN's Avatar
Quoted: 1670 Post(s)
picture please
are you sure you cut them there are some that are for you to use and pass through the firewall they are customer access wires
We Miss you Ronnie
ZMANN is online now
post #3 of 7 Old 05-14-2014, 08:56 PM Thread Starter
ok so after i played with everything my brake like on the dash is staying lit and the right front blinker is out.
post #4 of 7 Old 05-14-2014, 09:00 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
02s dont have the customer access wires like the 05 ups do ZMANN
Sent from AutoGuide.com App
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 7 Old 05-14-2014, 10:03 PM Thread Starter
i dont think its to serious but occasionally this thing wont lock into park and keeps rolling and now wont start unless its in neutral
post #6 of 7 Old 05-14-2014, 10:23 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 410 Post(s)
That would be the column torx screws loose. Look at where the shift cable hook to the bracket on the column. Its more than likely loose. T27 torx is the size IIRC. It has 2.
@loxdce
LoxDiesel is offline
post #7 of 7 Old 05-14-2014, 10:28 PM Thread Starter
cool. well ill fix that tomorrow and cut the rubber boot and splice the wires back together tomorrow. i think the only way to "repair" the wires will be to cover it in liquid electrical tape when i am done.
is that harness hard to find and replace?
