Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Body 911
Old 12-12-2008, 07:02 PM
flowmasters40 flowmasters40 is offline
Send a message via AIM to flowmasters40
HELP!! locked keys inside
my buddy locked his keys in his single cab f350 2000 single cab any help would be great
Old 12-12-2008, 07:08 PM
Jake Jake is offline
<--Mah Homey G Thang Ride
They are about the easiest vehicle to break into if you dont' mind doin a bit of damage, otherwise just use a slim jim. Or bend a coat hanger strait except the hook on the end, stick it between the window and the seal and lift up on the lock mechanism. Not sure where you are located, but be careful if it's cold, the windows are way more brittle. I accidentally busted my car window trying a slim jim. Made it easy to get into though .
Old 12-12-2008, 07:13 PM
yea we wanna do the least damage possible and it doesnt have power locks
Old 12-12-2008, 07:39 PM
Yeah, slim jim or hanger is your best bet. Or call a locksmith. That will run ya some $$$ though.
Old 12-12-2008, 07:47 PM
Strokin & Smokin Strokin & Smokin is offline
Jersey Strokers, Director
Send a message via AIM to Strokin & Smokin Send a message via Yahoo to Strokin & Smokin
call aaa they come and get you in if you were in nj id come help ya out. i have a litle bag like at the doctors they use to take blood preasure but its made for lock outs. but any way what i would try is take a door jam, try to wedge it into the door as best as possible, and get a coat hanger, bend it the right way and youre in.
Old 12-12-2008, 07:48 PM
Aljay Aljay is offline
Onstar OPPS wrong brand But yes those trucks are easier than my OBS to break into.
Old 12-12-2008, 07:50 PM
2005F250 2005F250 is offline
Sledge hammer thru the window, duh. or the slim jim thing
Old 12-12-2008, 07:55 PM
szyd szyd is offline
Get youre self a wedge of wood or a door stop wrap in a rag wedge it in at the top of door sill where the door meets the roof. Take a 3' section of #9 wire and thread it thru and grab lock. Or a slim jim works well to you just have to grad the lock rod which is horizontal and pull you will know when you are on it it will move a little but dont go pullin on just anything in the door you kan use the wedge to gain room between window and door just be carful only pry enough for slim jim to work freely. the cops or tow truck will use these methods.
Old 12-12-2008, 08:01 PM
7004 7004 is offline
got a brick ?
Old 12-12-2008, 08:10 PM
Goolsbymd Goolsbymd is offline
Project Abused
take a screw driver and hammer it through the key hole.
edit: damnit wasted post 1000
