New GPR, now no power anywhere - Ford Powerstroke Diesel Forum
post #1 of 17 Old 12-21-2013, 08:53 PM Thread Starter
97 7.3, no power what so ever, just drove it for about 30 miles then shut it off and went to start it again, the WTS light did not come on then the interior lights flickered and now nothing on the truck has power, fuses are all good, has a new starter and I put a GPR in it 3 days ago, battery terminals were cleaned a couple weeks ago, has anyone else experience this?
LeakyOBS is offline
post #2 of 17 Old 12-22-2013, 08:47 AM Thread Starter
cleaned battery terminals again, now truck has power but cranks ridiculously slow like the batteries were dead but nothing changes when i jump it with another car
LeakyOBS is offline
post #3 of 17 Old 12-22-2013, 09:01 AM
95sorensonOBS's Avatar
Have you tested your batteries? Through them on a charger and get them charged up all the way see if that helps. Powerstrokes take a lot of juice to turn over
95 powerstroke
Ts 6 pos chip
Rosewood stage 1 injectors
Afe intake
3"downpipe
4" straight pipe
95sorensonOBS is offline
post #4 of 17 Old 12-22-2013, 09:03 AM Thread Starter
i had them hooked to another car with jumper cables, and had the batteries load tested less than a month ago and came up perfect
LeakyOBS is offline
post #5 of 17 Old 12-22-2013, 09:11 AM
I had to replace my batteries just last week, tested good, wouldn't start my truck if it didn't fire right away. jumping was impossible unless I had big gauges jumper cables and another powerstroke jumping off of both batteries. Even then I'd be lucky to get enough of a charge to start it. Do you have a voltmeter or anything to test the batteries to make sure you got juice
95 powerstroke
Ts 6 pos chip
Afe intake
3"downpipe
4" straight pipe
post #6 of 17 Old 12-22-2013, 09:13 AM Thread Starter
Unfortunately not I can't find my voltmeter and have no way of going and buying one haha this sucks
LeakyOBS is offline
post #7 of 17 Old 12-22-2013, 09:18 AM
Try taking your jumper cables, connect them to the truck, touch them together and see of it sparks haha,
95 powerstroke
Ts 6 pos chip
Afe intake
3"downpipe
4" straight pipe
post #8 of 17 Old 12-22-2013, 09:19 AM
That are you trying to jump it with?
95 powerstroke
Ts 6 pos chip
Afe intake
3"downpipe
4" straight pipe
post #9 of 17 Old 12-22-2013, 09:28 AM Thread Starter
A god damn Oldsmobile alero I know it probably doesn't have enough juice but nice jumped my stoker with it before, yes they would arch the truck shows close to full voltage on the gauge so I'm assuming its somewhere around 11-12 v and I understand that if its not getting full voltage it wont crank fast enough but it should crank more than it is, its turning over once every like 2 seconds
LeakyOBS is offline
post #10 of 17 Old 12-22-2013, 09:30 AM Thread Starter
Just got it, starter connections were a little corroded even though the starter is brand new. month ago but I cleaned em and she cranked right up, thanks anyway man appreciate it
LeakyOBS is offline
