Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Body 911
Old 07-07-2008, 06:30 AM
moto moto is offline
power window problems
need help with my windows 1997 f350 crew dually back drivers side window wont go up went down fine . thank for any help
Old 07-07-2008, 08:26 AM
dhanna6powerstroke dhanna6powerstroke is offline
Got Smoke?
Won't work with either switch?
Old 07-07-2008, 08:32 AM
no wont work with front of back
Old 07-07-2008, 08:35 AM
Matt P Matt P is offline
<-- Endless Money Pit
your power window motor could be burnt out, happened to me with both my windows on my 86 F150 they went down but then wouldnt go back up, replaced both the motors and they work fine, its only like a 50 dollar part from lmctruck.com
Old 07-07-2008, 08:55 AM
thanks for the info
Old 07-07-2008, 02:18 PM
Got Smoke?
Could also be the master switch. If the master switch is bad on the up side, the other switch will not work. The back switch completes a circuit somehow through the master switch.
Old 07-08-2008, 05:19 AM
when you say master switch do you mean switch on drivers door
Old 07-08-2008, 05:34 AM
Got Smoke?
Yes. That switch has to work for the other ones to work.
Old 07-08-2008, 07:18 AM
thanks i'll be looking at that next
Old 07-08-2008, 07:23 AM
Got Smoke?
If you have a friend with the same truck, you could just swap switches and see if it works. Would save you some money.
