Ignition stuck off, key wont turn - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-26-2013, 08:59 AM Thread Starter
2000 F450, 7.3 liter, The keys(tried all 3 of them) will not turn the ignition in the slightest. No amount of wiggling, jiggling and just plain abuse of the steering wheel or the automatic transmission shifter will unlock it.
Possibly the neutral safety switch? Anyone know of a common issue with this aside from the usual key stuck in on and wont turn off?
Sparklighter is offline
post #2 of 5 Old 09-26-2013, 09:36 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
My key did something similar to this. I had to get a new key cut. My factory keys had worn down and wouldn't engage all the tumblers
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 5 Old 09-26-2013, 10:10 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Is the steering wheel locked? If you turn the wheel when the truck is off it locks and makes it impossible to turn the ignition on. To fix it you have to turn the wheel while you turn the ignition. Maybe thats your problem
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #4 of 5 Old 09-26-2013, 03:17 PM Thread Starter
Love tap
After finding the schematics for the column and pouring over them to locate a possible cause, Checking the column lock didn't work. I used my magic hammer. Googling, I found another who has has this problem and he simply tapped the key into the ignition with a small hammer twice. I did this after hosing the innards with WD40 and viola, it freed up immediately.
post #5 of 5 Old 09-26-2013, 03:41 PM
STANGMAN893's Avatar
Mine did this and I had to replace the cylinder. Had to drill it with isn't too bad. pull the covers off the bottom of the column and right under the cylinder is a pin that locks the cylinder in place. Drill that out and comes out with a little motivation.
STANGMAN893 is offline
