Power windows not working! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-30-2013, 12:51 PM Thread Starter
I could really use some help on this one folks! I was rolling up all four windows the other night and the back two stopped about half way up. I have no control at any window. I have checked all the fuses inside and out and jumped all the relays around inside and out. I cannot for the life of me figure this out and it is keeping me from being able to drive anywhere that I have to park my truck outside for a while. Any help or ideas would be more than appreciated.
2001 CCLB DRW 4X4, 6spd, TW 6 Pos, 6637, 4" turbo back, 203* stat, Driven Diesel Reg Return, HPX, CCV mod, 33" all terrains
Project Luxury Work Truck
SSonnier is offline
post #2 of 6 Old 05-31-2013, 11:29 AM Thread Starter
Anyone have anything that might be helpful? I have tried searching everywhere for an answer but I haven't found a situation like mine. Everyone else says their dome lights, radio, or gauges stop working when the windows stop. The only thing not working here is my power windows. I'm going to pull the door panels and see if I'm getting 12v at the motor connection. But I seriously doubt all four window motors went at once.
If I can't get it fixed before it is time or me to leave for work I'm just going to have to put jumpers wires on the rear motors and make them go up. I have a/c so it won't be too bad.
SSonnier is offline
post #3 of 6 Old 05-31-2013, 07:56 PM
jimhuntertx's Avatar
Quoted: 3 Post(s)
Send a message via Skype™ to jimhuntertx
You might try this...
In years past on fords I found that the window control panel in the drivers door goes bad. When it fails none of the windows will work at all. If you have a buddy who has the same type of control panel you might be able to just plug it and in and see if it works. Good Luck.
Jim
97 F-250 2wd Extended Cab Longbox, Pyro,boost and trans temp guage, 3" down pipe,
New E4OD Trans, TS 6 chip
Banks TransComander, 4" to dual 4" Bullydog 4" Dual Exahust , DIY Tymar intake w/ K&N Filter, Shimmed FPR
jimhuntertx is offline
post #4 of 6 Old 05-31-2013, 08:10 PM
michaelbyoung's Avatar
Mine is an 06, and one day all quit working. It was the drivers side switch control as stated above. I took it apart and cleaned it a bit, plugged it back in all worked again. Still going now.
Sent from AutoGuide.com App
2006 F-350 Lariat Crew Cab Long Bed 6.0 Diesel
Chrome Pkg All Stock 185,000 miles
B&W Turnover Gooseneck w/ 5th wheel companion
ScanguageII High idle mod On board air
2011 Jumpseat Gutted Cat Mikeymod muffler
EGR delete CCV mod EC1 coolant Zoodad mod
2000 F-250 Lariat Crew Cab Short Bed 7.3 Diesel ***STOLEN*** 11/19/2011
4" Rancho Lift
215,000 miles
afe intake
4"turbo-back
IAH delete
Foil Delete
michaelbyoung is offline
post #5 of 6 Old 05-31-2013, 08:12 PM
Luckily it wasn't bad, just needed to be cleaned.
4" Rancho Lift
215,000 miles
afe intake
4"turbo-back
IAH delete
Foil Delete
post #6 of 6 Old 06-03-2013, 04:25 PM Thread Starter
Well I checked for power at the plug to the window switch and got nothing. Does anyone happen to have a wiring diagram for the power windows or know off hand where the power supply comes from?
SSonnier is offline
