need help - Ford Powerstroke Diesel Forum
Old 01-31-2013, 06:44 AM
need help
my 99.5 f350 dually just started acting up when you turn it of the radio, wipers, and power widows all still work and it keeps draining my battery anyone have any ideas what is doing it
Old 01-31-2013, 01:36 PM
Has it been raining a lot where you are? There's an issue, where the lower corners of the windshield leaks into the cab. On the drivers side it drips into the GEM module (on the backside of the fusebox) and will make all sorts of stuff go "crazy"
Have a look up there for evidence of water getting in...
Old 01-31-2013, 05:28 PM
I'll check tomorrow it's been raining some up here
Old 02-14-2013, 02:39 PM
I have had the same issue. It was killing my batteries. What I found was 2 issues. The Ignition was worn so I turn the key backwards after shutting the truck off then turn it to the off position to get the key out. I also found Safelite in there infinate wisdom cut my broken winshield out years ago and never primed the scratch the knife left. It caused rust and the paint to bubble under the window seal. That caused water to leak in and do all sorts of crazy things. I took a wire wheel and cleaned it out the best I could and applied rust converter and a sealer. My issues are currently gone.
I figured once my truck hit 500K I would get a body shop to fix it right for it's birthday. They want $850 to $1850 depending on if it needs a new roof skin.
