Please Help. Trailer connector issue
Hi,
So 2003 F-250 I have parking lights but no Turn/Brake lights at the plug, I checked fuses under the dash and the 2 fuses in a box beside the master cylinder. when I turn on the turn signal the relay clicks underneath the hood so that tells me the relay is okay, Anything I am missing, Racing season starts tomorrow and I can't tow with my new tow rig..... ARRRRRRRRRRRRRRR!!!!!!!!!!!!!!! Im subscribed to this thread so I will answer immediately! |
BTW I used the search function and came up dry... Nada!
Replace Plug
Hello - Not sure if this will help - it did help me.
I have 2001 F-250 7.3l My trailer light worked sometimes and no breaks. I took off the connector and the pig tail. I found the connection between the pig tail and the connector full of dirt and very rusty. I purchased a new connector and it worked perfectly. I did break the plastic connector between the pig tail and connector (on the pig tail) so I just used some electrical tape to hold it together for now. |
actually, i found a fuse that I changed out, and that fixed it,
didn't look blown but looked like it had been "Hot" I changed it and they work perfect, I also ended up changing the plug thinking that may have caused the fuse to get hot... all good! Check the fuses, all of them.. |
