- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
need help! w/sway bar links ?truck is on stands right now
Here's the situation. The Hanes book tells me to lift the front end off the ground. the problem is if I raise the truck by the frame, the jack doesnt' extend high enough to get the tires off the ground. Just short. Is there another point up front so the jack can get the tires up? Like using the front axle.
Also how the heck to you loosen the top nut, passenger side. the tranny housing gets in the way of a short socket & breaker bar from getting up there. I was hoping to save some money on labor, but this is maybe a little out of my league. First time owning a full size truck, and a learning experience it is. |
| Sponsored Links |
should I only lift it a little bit to take the tension off? As for the socket, I tried a reg. ratched. There is no room to be able to fit between the tranny housing/starter. They are to close to the nut. Don't tell me I have to drop the starter? I wonder if this why the dealer wanted $310 to change them. |
not sure if you gotta take the starter or not they are not hard to pull and just use a box wrench if you dont wanna take it off. lift it as much as you want to it will just give you that much more room to work just make sure to chock the rear wheels and put the jack stands in a solid location so you dont get hurt |
The problem is that I'm at work, and left my stands back at home. So I have a bottle jack on one side, & the floor jack on the other. Is that what I'm supposed to do, is let the tires hang. What about the tension. I started to take off the bottom passenger side nut, and I could tell that there was tension, because the sway bar began to move as the bolt was being backed out. I just don't want to get stuck and not be able to put this thing back together, cuz it's in my station. |
yea I think I'm going to have to wait till tues to get to it again. maybe i can get some pointers about this job. I think there is more to it than meet the eye. thanks for your help jethro.
| Sponsored Links |
