Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Bio-Diesel/Alternative Fuels and Supplements
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 05-25-2009, 10:20 PM
Dieseltorkin Dieseltorkin is offline
Send a message via Yahoo to Dieseltorkin
Large SVO Tank
Ive got a large steel fuel tank that would make a good storage tank for SVO its between 1500 and 2500 Gallons. Make me an offer. Located in missouri. Ill measure the tank and run the math later and post the exact Gal specs
Old 05-26-2009, 01:18 PM
ridiculously_necessary ridiculously_necessary is offline
man i wish i had the space! do you run wvo?
Old 05-26-2009, 01:21 PM
wriott wriott is offline
BUILT & BROKE BY ME
where at in missouri, pics would be great along with dimensions. what is the sidewall thickness (if you can get that) any other info would be great.
Old 05-26-2009, 01:25 PM
sea71 sea71 is offline
Maybe Im wrong, but doesnt steel and wvo have problem when together? Isnt there a reaction between the 2? I could be completely off base here but I seem to remember the fellas on the wvo forums saying not to use steel in bed tanks with wvo. Would this size tank do the same? Just curious, cause Im looking for a finished fuel tank to store in. Thanks.
Old 05-26-2009, 01:30 PM
BUILT & BROKE BY ME
no idea, im look at if for diesel so it dont matter to me, good point i would also like to know
Old 05-26-2009, 02:04 PM
Its a Diesel tank, im headed out now to take some pictures and Measurements. Has A man hole cover bolted on top and a spigot at the bottom for filter and hose.
Old 05-26-2009, 02:17 PM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
This is spot on Shane, Vegi oil will polymerize when in contact with steel, copper, and a few other metals but no problem with Aluminum and plastic.
If you want this tank for vegi, don't waste your time and money.
Old 05-26-2009, 03:02 PM
The tank is 78" in diameter and 120" Tall. If i did the math right thats 2482 Gallons. Couldnt measure the thickness. I would image its 3/16 or 1/4
Old 05-26-2009, 03:52 PM
BUILT & BROKE BY ME
yup i also get 2482 gals, do you have any way to load it??
Old 05-26-2009, 04:00 PM
Ive got a tractor and loader with pallet forks. Loading is not a problem at all
