- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
diesel secrets?
anyone heard of or better yet tried diesel secrets product? just found it online and curious if anyone has tried it. the way they make it sound its as easy as getting used cooking oil, filter it, add there chemical, pump it in your tank and drive. they even say it's good for your home heater. the web site is dieselsecret.com sounds to good to be true for $.46 a gallon to make own fuel.
| Sponsored Links |
waist veggie oil is a great idea, if you do it right. i actually have been doing as much research as possible as it would be really advantagous for my girlfriends dad...who tows a large fifth wheel.....im no expert, but from what i have gathered, it is either do it right....or you will be messing with it over and over again. try PMing veggie destroyer....he has done his own and i bet he has so me trial and error for ya....i would be really scared of any chemical that would change the complexity of any potential fuel product, instantly supposed to make it burnable.....just my opinion......
well i did a little research on this secret diesel thing. and from what i've read you add a few things to the oil. one of which is unleaded gasoline. and they're mystery chemical is some kind of paint thinner supposedly colored with dextron. i found this info on some biodiesel site. can't remember exactally what all they said about it but it did not sound good. you know what they say, if it sounds to good to be true.
Cheap fuel
They had a program on that do-it-yourself TV show and used old cooking oil plus lie and something else. Willie Nelson is pushing it a-lot. I understand that it burns clearner and smells like french fries out the exhaust. I have had some come into our shop and the grease around the fill neck is enough to turn me off. Mike OB
brew your own
the only problem, your not supposed to use the fuel on the road. since it is not taxed, it is considered tax evasion, and yes people have been charged for it. there is dye in fuel so it can be checked easy on the roadside. (d.o.t) people used to use heating oil because it was cheaper. as far as burning veggie oil, it needs to be heated up to 170ish degrees to be able to flow and burn in the motor. there are kits to buy that runs coolant from the engine to the holding tank for veggie oil. you have to start the truck on reg.fuel first (to warm engine coolant up) then switch to veggie tank. i think it would be great to run veggie oil, but its alot of work if you collect the oil yourself. it must be strained very well to use. |
| Sponsored Links |
