- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
| Sponsored Links |
Ive been using diesel secrets in my truck and my dads work truck for 6months now and had no problems! As long as you follow there instructions...only thing I would recommend so you don't eat up filters all the time would be to run ur grease through a water heater to rid it of excess water and to use cloth fliters when putting the grease into barrels to rid it of the bigger chunks and what not...
d.s.e. is garbage imo is has costed me over $3000 in repairs for trying to save a buck.i have learned the hard way to do it right or dont do it.dse is nothing but thinned out wvo.if you learn the basics of biodiesel you will see it is very unrefined so unless you are a wvo system i would not mess with it or you will be looking at problems in the near furture imo.none of the dse process deglyeride and deacidfided (sorry for my spelling) you get the point.the is no washing ect. ect. there are reason for doing those process. if you dont imo you wil have problems. maybe not right now but you will and it wont be cheap so save your money you will need it.
What does water do when it hits an injector? IT's under high presure first of all and water under presure has a much lower boling point. When injected, the water is introdeced to lower pressure and extreme heat. This causes an extreme explosion of gases (although very small) as the water turns to vapor instantly. This all happens at the injector tip. Enough said? Try taking a gallon of used vegi oil and let it settle for say 2 weeks in a glass container. Don't disturb the sample at all durring this time, let it sit in a warm place. You will see a layer of water and particle mater form on the bottom of the container. Last edited by CHenry : 12-13-2006 at 08:58 AM. |
heat the oil for 4 hours....to 140* then let it cool to 90...a couple days. drain off the lower 5 gallons and throw that away. The rest should be water free.
| Sponsored Links |
