Originally Posted by Badfish740
First and foremost, straight vegetable oil and biodiesel are NOT the same.
Correct and so many people don't realize that.
Biodiesel is SVO that's been "refined," but not refined as in cracked, like petroluem products.
wrong, the transertification process changes the molecular composision of the vegi oil.
Biodiesel is made by reacting SVO with sodium methoxide (a mixture of lye and methanol)
In biodiesel production, methoxide is incorrectly referred to as the product of mixing methanol and sodium hydroxide. Since this reaction generates copius amounts of water as a by product, this reaction is unlikely to produce any substantial amounts of usable sodium methoxide (NaO-CH3).
Some vehicles seem to tolerate biodiesel better than others From what I've seen the 6.0L doesn't seem to tolerate it well, but the 7.3L seems to be able to handle mixtures of 75% (B75) to 100% (B100) bio just fine (the other 25% being regular diesel), so blending in small amounts to begin with is recommended.
I don't agree with this, and i have no real evidence to back it up, i just don't agree. Any diesel engine will burn Bio-D fine as long as the Bio is water free, filtered properly and of course has the glycerins completely removed. Of couse the fuel system needs to have viton seals or other material that will not disolve because of the corrosive nature of Bio-D.
SVO on the other hand requires modifications to the vehicle which basically entail a seperate tank/pump/filtration/delivery system for the SVO, and a method of heating it to operating temperature.
Most of this is right on except a little vague. Initially the oil only needs to be warm enough to flow through the lines and filter, then upon reaching the injectors it must be 160* before injection..."operating temperature" is hotter than 160.
The heating is usually accomplished by using waste heat from engine coolant and 12V heating devices.
Usually? This is the only way you can heat it that I am aware of.
You can't run SVO without A: filtering it to at least 5 microns, B: ensuring that there is absolutely NO suspended or free water in it, and C: heating it to at least 120 degrees F so that it is sufficiently thinned.
All of this I agree with except the 120* which you already noted was a mistake.
If you fail to take one or more of these steps, at the very least your fuel filters will become plugged, and at the worst you'll destroy your injection pump.
Correct, but PSD don't have an IP....so lets say destroy your injectors instead.
SVO at normal temperatures (say 72 degrees) is just too thick to be handled by an injection pump. At that temp SVO has about 30 times the viscosity of #2 diesel.
The main point of heating, again, is proper atomization when injected. Pumping thick oil may shorten the life of an IP unless your talking about a Benz - which a Benz IP could pump cement and last forever - but again asuming we are talking about a PSD, there is no mechanical IP.
If the oil has water suspended in it (all used fryer oil has a lot, all new oil has a little)
This is very misleading. It depends where you get your oil. Mine comes straight from the fryer, those fryers operate at or above 360*, water will not suspend and remain in the oil at that temp. It is cooked off. If you get your oil from a dumpster where the lid has been opened exposing the oil to rain, you will have free water in the botom of the dumpster and some suspended water simply from humidity in the air. My oil contains less than about 100 ppm when i collect it. That means only a couple of drops settle out of a 50 gallon batch.
And i have seen documentation showing that new oil containes less water than the diesel fuel at your local truck stop. Also not ALL new food grade oil has the same water content but all contain very very small amounts that are withing tolerances for our truck engines.
the water will be rapidly turned to steam when it enters the injection pump. Once this happens the mini steam explosions will cause pitting on the various metal surfaces inside the pump. Finally, just like with fuel, filtration is important, most anyone who uses SVO filters to 5 microns (if not smaller) before the fuel hits the IP.
Correct, but again, don't forget this happens also with the injectors.
There is so much technical stuff involved with this that it is very difficult to write a post like this and include enough information to completely back up everything with facts and also explain it well enough for the average Joe to read it and completely understand it...so i wanted to try and clear this up a bit - yet I still can't do it completely because there just isn't enough time in my day to type it all out. So don't take offense, i wasn't picking on your post.
