Heating/warming a tote? - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 6 Old 07-18-2014, 11:18 AM Thread Starter
tubular031's Avatar
I have some oil that is full of fats and thick stuff. I can heat it up and it thins out nicely. Right now I can pump it around no prob or gravity feed it but that is because its 100 out. I am looking for a way to heat a tote up. I need maybe 100 deg in the tote to get the oil thin enough to gravity to my CF where I have a heater that gets it to 160 deg.
I have seen some nice tote wrap blankets to heat the tote but they are $1600 bucks. There is a company that makes a heat pad that goes under the tote to heat it up but that is $600 ish. I have in the past used a HWH element dangling in a tote or barrel (not touching the sides!) and that worked ok but slow. Price was less than 20 bucks. I have thought about using waterbed heater pads under/around a tote to see if that works.
I have a 25 gal hwh available so I thought about running a big heat loop in the totes with pex or something like that (cheap and easy) and then heating up the water and using a small pump to circulate the water. more tube = more surface area to warm the oil.
Looking for other ideas if anyone has them!
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #2 of 6 Old 07-18-2014, 11:53 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
Pex doesnt conduct heat well. If you went that route, use aluminum tube.
I would check all the thrift stores for a water bed heater. Then the only issue is getting it under the tote with good contact.
A bucket heater dropped in the top would be my next choice. Drop it in all the way on the bottom and leave it for 3-4 hours.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #3 of 6 Old 07-18-2014, 12:21 PM Thread Starter
tubular031's Avatar
I am kinda leaning towards the heat loop because that opens the door for a solar heat collector too. Dang my redneck engineer mind is going crazy with ideas.
I know they use PEX in radiant heating so I figured it would work here too. I did not think plastic tub was all that good anyway.
The down side to the waterbed heater is they are usually 200-300 watts. that seems pretty low power wise and I fear it will take a long time to warm the tote.
post #4 of 6 Old 07-18-2014, 12:41 PM
Use black poly pipe
04 F550
jonesy_11950 is offline
post #5 of 6 Old 07-18-2014, 12:44 PM
Same type 1/2" used in heating swimming pools use 12v solar panel and run 12v pump to keep water moving
04 F550
post #6 of 6 Old 11-21-2014, 12:06 PM Thread Starter
tubular031's Avatar
In case someone stumbles onto this in the future, I did an experiment with some pretty cool results. You can see it here Tote Heating Experiment
