Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Bio-Diesel/Alternative Fuels and Supplements
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 01-22-2009, 09:54 AM
veg oil and gasoline
i have about 25-30 gallons of clean veg oil mixed with about 3 gallons of gasoline. a miscommunication occured and gasoline was poured into the wrong drum.
would it be alright to run this in my truck?
Old 01-22-2009, 09:56 AM
Obama sucks
Dilute it with some diesel. Run it a little at a time you should be fine
Old 01-22-2009, 09:58 AM
Sooner Powerstroker Mod
i wouldn't run it i don't think but like dave said, dilute it in several gallons of diesel if you do.
Old 01-22-2009, 09:59 AM
any chance the gas would settle out of you let it set? Never tryed that before but if it did, you could just pump off the top and leave the gas there.
Old 01-23-2009, 06:36 AM
I would look on this site for the threads related to blending with RUG (Regular Unleaded Gasoline). I make Bio Diesel rather than blend, but those folks should be able to tell you what proportions are acceptable to use as fuel.
Old 01-23-2009, 08:59 AM
my blend ratio was 10:1 regarding wvo/rug, plus other ingredients.
Old 01-23-2009, 10:08 AM
Maybe you can help CajunDave salvage his oil then.
Old 01-23-2009, 10:33 AM
dubl t
__________________
what other ingredients? kerosene?
Old 01-23-2009, 10:57 PM
40gal WVO, 4gal RUG, 32 oz PowerService, 1gt Marvel Mystery Oil, 1qt Stoddard Solvent or mineral spirits, and thin with dino, kerosene, or home heating fuel depending on what's cheapest.
This is what got me started:
dse in truck 04-05 CTD - TDR Roundtable
There's alot of different blends and formulas, and each truck reacts differently, so experimentation is necessary.
Tom.
Old 01-23-2009, 11:13 PM
I'd run it, maybe add some 2 stroke oil to it though. Run a few gallons at a time. If nothing odd happens double what you had run before. If it starts to run odd top off the tank with #2 and drive it that way. I think you should be fine but it will clean out the tank and lines so be prepared to replace the fuel filter.
They speak about it here, POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
