SVO/WVO kits - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 64 Old 07-05-2014, 10:16 AM Thread Starter
SVO/WVO kits
So I've been reading up on SVO/WVO and I'm ready to do it.
Can anyone give the low down on the different kits out there. Their history and the good/bad/ugly...
Thanks!
7.3dieselMike is offline
post #2 of 64 Old 07-05-2014, 02:51 PM
Having installed several brands of kits, and numerous DIY builds and rebuilds, I'm pretty comfortable with it all. First off, let me say this: know and understand that WVO is not considered 100% safe. I In fact no longer recommend WVO.
I do feel that a properly accessorized BFT Vegistroke is a good quality kit. I personally wound not consider any others manufactured kit currently available. Depending on the climate you live in, your accessories may vary. I recommend LARGE (40 plate) FPHE for cold weather use (below freezing operations).
Whatever you decide, know and understand exactly how the system you choose operates. Knowing what failed when the system does is the first step to avoiding frustrations involved in entertaining alternative fuel use.
Oh yah, I forgot to mentoom that a PSD GC kits should be avoided even if free. That's what they are worth IMHO.
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
post #3 of 64 Old 07-06-2014, 11:40 AM
Quoted: 3 Post(s)
yes go DIY and save the troubleshooting hassles.
Early 99 crew cab long bed SRW
Vegistroke V3.
Support Grease Mafia on Facebook
erbilabuc is offline
post #4 of 64 Old 07-07-2014, 08:54 AM Thread Starter
Thanks for your post vegginpsd, it was very informative.
Why?
Any thoughts on Golden Fuel Systems?
I live in the hot & humid subtropics with very mild winters, maybe half a dozen freezes & fewer every year as things heat up.
But I may not always live here.
post #5 of 64 Old 07-07-2014, 08:55 AM Thread Starter
Cool! I love DIY! Any pics or info on your setup you'd like to share?
post #6 of 64 Old 07-07-2014, 09:00 AM
If living in a warm climate, I recommend converting the fuel, not the truck.
Consider building or buying a quality biodiesel reactor. I'm much happier on B100 than I ever was on WVO.
99 F350 7.3
B100 by Biopro 190
post #7 of 64 Old 07-07-2014, 10:13 AM Thread Starter
I want portability.
What happened with WVO?
post #8 of 64 Old 07-07-2014, 11:19 AM
A biodiesel reactor will likely take up less space than a CF setup. Likely be more portable too.
As far as WVO, I've seen way too much engine and system failures to promote its use. Pumps, valve guides, failed hoses, injectors, etc.
I was served pretty well by WVO personally, however, since switching to B100, life has been much easier. I will never burn WVO without transesterficatioon ever again.
99 F350 7.3
B100 by Biopro 190
post #9 of 64 Old 07-07-2014, 11:47 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
whats this about wvo?
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #10 of 64 Old 07-07-2014, 11:59 AM
What you talkin bout Willis?
99 F350 7.3
B100 by Biopro 190
