Is Methanol & Methane The Same? - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 01-12-2009, 04:34 AM
The Screwy HEUI
Question Is Methanol & Methane The Same?
I'm a drill rig tech....er...I was a drill rig tech. Some of the drill rigs I've commissioned were @ landfills where the company purchasing the rig would be drilling for methane gas. Although methane gas from a landfill has a cryptic stench(well, for those who don't know---smells like the worst fart EVER!), it's used to power entire cities. I guess what my question is, is methanol & methane the same thing? & if they are, can methane be used as an alternative fuel in a diesel engine?
Old 01-12-2009, 06:22 AM
Definately different. Methane (CH4) = basically natural gas. Methanol (CH3OH) = wood alcohol.
Old 01-12-2009, 07:28 AM
The Screwy HEUI
Proving once again you learn something new everyday! But since diesels can supplement off natural gas, can they use methane?
Old 01-12-2009, 09:24 AM
According to Union Gas, the composition of natural gas is as follows:
Component Typical Analysis
(mole %) Range (mole %)
Methane
94.9 Range 87.0 - 96.0
Ethane
2.5 Range 1.8 - 5.1
Propane
0.2 Range 0.1 - 1.5
iso - Butane
0.03 Range 0.01 - 0.3
normal - Butane
iso - Pentane
0.01 Range trace - 0.14
normal - Pentane
0.01 Range trace - 0.04
Hexanes plus
0.01 Range trace - 0.06
Nitrogen
1.6 Range 1.3 - 5.6
Carbon Dioxide
0.7 Range 0.1 - 1.0
Oxygen
0.02 Range 0.01 - 0.1
Hydrogen
trace Range trace - 0.02
Specific Gravity 0.585
0.57 - 0.62
Gross Heating Value (MJ/m3), dry basis *
37.8 Range 36.0 - 40.2
There are more trace elements than I thought there would be. However, the ratio trace elements to methane is pretty low so I would hazard a guess that it wouldnt be a problem. I am no chemical engineer though so I certainly wouldnt claim to know for certain either way.
I am assuming you are talking about filling canisters of methane off of the compressed stream at a landfill plant. That would certainly be cheap supply, I'm just not certain how well it would work out in the long run.
Old 01-12-2009, 09:27 AM
Just found this as well Landfill Gas "LFG"
So if you are talking about the refined stream off of a methane plant at a landfill that would be one thing. This "LFG" looks like a BIG no-no!
Old 01-12-2009, 09:40 AM
The Screwy HEUI
Well thanks, Davey! You sure you're not a chemical engineer? This is THE most educated & detailed response I've ever gotten for a question. Thanks for the link as well. It taught me more stuff than I could've imagined!
