Vegistroke in a 6.0 - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 01-10-2009, 11:17 PM
Vegistroke in a 6.0
I am putting my Vegistoke from my 00 into my new 06 Lariat, and just wondering what others have noticed with running WVO in the 6.0. I am getting all the lines and wiring run so when the new engine fittings come in hopefully monday I will be running vegi again!!!
I have seen the post about the the being less of a heat source and plan on putting coolant pump on the return line.
My truck is a Lariat so it has all the fancy stuff like the trip computer, Does anyone know how the truck calculates fuel economy? Does it measure the fuel flowing to the heads, tank level, or injector pulse? What I am wondering is the vegistoke shuts off the diesel pump and supplies the vegi completely separate, so is the fuel economy going to read just what diesel went through, and just keep counting until it hits 99.9mpg? Does it confuse the computer?
Let me know what you guys have seen
Old 01-11-2009, 12:08 AM
say no to rolling coal
PM Clay (CHenry) I'm sure he'd love to check out this thread. He's got plenty of experience burning vegi in his 6.0
Old 01-11-2009, 09:04 AM
I am going to eventually, want to open it up for everyone else to see so its not just a private convo between us.
Also reading through the new version of the vegistoke installation instructions it says the fuel lines run down the bottom of the motor and over to the V3 module?
Old 01-12-2009, 07:12 AM
the 6.0 uses a different bolt at the heads. Its some kind of banjo bolt where as the 7.3 uses a Check Valve and NPT threads. other then that its about the same (i think)
