Fuel economy went to crap after a tank of bio - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
 1Likes
post #1 of 11 Old 06-14-2014, 07:14 AM Thread Starter
I just bought a 2000 Ford F250 7.3L a month ago with 230K, mods are edge attitude, straight pipe and 36in tires
When I first got it, it was getting pretty decent fuel economy. I recently filled up 2 tanks of B20 Fuel and now my fuel economy has gone to crap. Ive gotten 100 miles in a half tank of mixed highway city driving.
I changed the fuel filter but still crap. I couldn't drain the filter canister. i think it was clogged and I didn't have time to unclog it.
Do you think that might be why its not getting good fuel economy?
Thanks
Mike
geero808 is offline
post #2 of 11 Old 06-14-2014, 02:53 PM
You are barking up the wrong tree. B20, or any blend of Biodiesel, should have only a negligable effect (up or down).
Any change in drive ability that you noticed?
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
post #3 of 11 Old 06-14-2014, 03:36 PM
c dog's Avatar
I noticed 1 maybe 2 mpg less running B20. I thought I read some where it doesn't burn as hot as reg diesel.
c dog is offline
post #4 of 11 Old 06-14-2014, 04:57 PM
Even ASTM B100 cetane ratings vary, however, 2 MpG is a lot. As general guideline, the only noticeable difference between D2 and B20-B80 should be that the injectors are quieter.
99 F350 7.3
B100 by Biopro 190
post #5 of 11 Old 06-16-2014, 08:20 PM Thread Starter
No, no real difference in drivability. I just filled up with regular diesel the other day and my fuel economy is way better now. So maybe my truck doesn't like B20?
geero808 is offline
post #6 of 11 Old 06-16-2014, 10:19 PM
I know that when my truck had a sharp decrease in MPG I found out it had a sticking caliper. I replaced the caliper and my MPG sprang right back to normal.
Now, when I fuel up, I put the tank filling then walk around the truck touching each rim with the back of my hand. If one feels hotter than all the others, it may be dragging.
I hope this helps!
2007 F-350 W/Lariat package
4x4 6.0l diesel engine
Leveling kit and 35 inch tires
Coolant Filter kit
EGR Delete Kit
Glowshift Gauge Pillar Pod (EGT, Trans Temp, Fuel Pressure and Coolant Pressure)
Fuel System Blue Spring Upgrade
SCT Tuner
Diamond Eye 4" stainless steel turbo back exhaust kit
ScanGuage II
Zoodad Mod
Backup Cameras from Tadibrothers.com for both truck and 25' Travel Trailer
DJGut is offline
post #7 of 11 Old 06-17-2014, 01:23 PM
I still maintain there is something else...unless the MPG comparisons were hand calculated.
99 F350 7.3
B100 by Biopro 190
post #8 of 11 Old 06-18-2014, 11:25 AM Thread Starter
I can't calculate the exact mpg because my speedometer hasn't been calibrated to the tires. I have on the truck.
geero808 is offline
post #9 of 11 Old 06-18-2014, 12:16 PM
SuperCrutyPS's Avatar
Quoted: 318 Post(s)
Garage
I was going to suggest you change the fuel filter. Bio tends to 'clean' stuff out of the tank & fuel lines which ends up in the filter. But, if your truck's MPGs have come back up using Dino-diesel, that may not be it. It could be the quality of the Bio-diesel.
I filled up in Bend, OR once with B100. The truck ran like a top! I've used B20 around here and it ran just as well.
john galt likes this.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #10 of 11 Old 06-21-2014, 02:14 PM
john galt's Avatar
Quoted: 1313 Post(s)
just guessing here but is it possible the bio is either impure as Darryl said. or maybe the bio is bustiung loose old deposits that are straining through the filters I would try cleaning out the filter housing as thoroughly as possible when you get the time and changing the filters one more time and see if that helps
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is online now
