| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
Easy Biodiesel Recipe
Anyone got any easy Biodiesel recipe without lye? I just need something for demonstration not for use.
Or possibly substitute just so it looks like bio. ![]() Its for a Class Project and I was going to take a video of how I made it. |
World Famous Dr Pepper Technique (Pat Pend) - Topic Powered by eve community
WORLD FAMOUS DR. PEPPER METHOD This is what you want for a school project it is easy. If you read it,and learn some of the vocab the whole class will be amazed and think your Einstein. lol... |
I could imagine someone calling the police and they come in guns drawn to bust what they think is a drug lab! Make sure you are out of society's view if you do this!
no way around it bud - sodium hydroxide (lye) or potassium hydroxide (caustic potash) are the only things that'll make the reaction happen. besides, lye is easy to get - it's even on ebay!
unless your assignment is due on monday, in which case TS.
lye will be by the draino in a bottle. It will say 99.9percent Lye and will be white crystals look at United or wal-mart. I think it is called Roto. or try rubbing alcohol they wont know
I dont think Drain O is lye, if it is it has water mixed with it, and the reaction will never happen, becuase the Methanol will absorb the water and wont react with the oil,
Methanol you can get in the Yellow HEET fuel additive. 22% of whatever oil you use. Then for NaOH you can buy it at Lowes, Its ROEBIC crystal drain cleaner. Spoon in a few table spoons of lye with the methanol, shake it up until all the crystals dissolve, it will usually take a good 5-10mins and it will crate heat and pressure so be careful and crack open the bottle so it doesnt pop on you, then add oil, put it in a pot of water on the stove, and heat to 135 F for 10-15 mins, then shake it up and let it sit. It will separate for you, and the glycerin will go to the bottom. If you use too much lye it will just turn more oil than nessecary into glycerin. |
is it possible to make bio without Methanol, and use something else instead?
Ethanol has been tried with limited results. The methanol is a solvent combined with the lye the break the chemical bonds to produce biodiesel and glycerin byproduct. You'll see reference to a solvent thinning process by the trade name of Diesel Secret, many people call this biodiesel , but is no way biodiesel. Diesel Secret involves veg oil, unleaded gasoline ,kerosene , Powerservice additive and the secret ingredient sold by Diesel Secret. I know of many people who have tried this and have minor problems like filter plugging to total engine failure.
Drano might be lye,but roto is crystallized lye.
Drano has many different chemicals in the mix that inhibit the reaction. Roebic is 100% sodium hydroxide aka lye.
