Solenoid for filter - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 2 Old 05-26-2014, 11:49 AM Thread Starter
tubular031's Avatar
Solenoid for filter
I have been toying with the idea of putting a solenoid on the feed side of my CF. The idea is if the power goes out the VO supply to the CF will stop. This would be for safety only. I would still manually stop the flow with a ball valve when I turn everything off. My new filtering setup will be in my other garage and powered from a generator (for now...) The garage is not too close to the areas I hang out. I would still come by and check on it often but want some way to stop the flow to the CF if the gen stops or a breaker blows etc. Anyone have any suggestions?
Thanks
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #2 of 2 Old 05-26-2014, 05:16 PM
Do it.
I have a 220V Parker valve on mine wired inline with the CF motor for just that reason. Normally closed. Opens with CF motor power.
Handy for use in summer when power seems to go out a lot.
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
