maybe off subject a touch, Algae in diesel - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 3 Old 05-23-2014, 09:48 AM Thread Starter
working on an 04 6.0
opened it up to do studs and all updates.
found the fuel pressure check valve (brass piece) totally black and sticky with algae.
have you guys ran across algae issues in bio fuels?
if so how did you correct the issue?
thanks
Buckyb
bucky beavever is offline
post #2 of 3 Old 05-24-2014, 04:02 PM
Quoted: 3 Post(s)
100% sure its algae? algae isn't sticky so it could be 10 years of grime.
Early 99 crew cab long bed SRW
Vegistroke V3.
Support Grease Mafia on Facebook
erbilabuc is offline
post #3 of 3 Old 05-26-2014, 05:27 AM
B20 might be the solution, not necessaril the problem.
That or try some power service in the silver jug (diesel clean)
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
