Looking for a rubber hose - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 5 Old 05-19-2014, 06:46 AM Thread Starter
tubular031's Avatar
I am rebuilding my filtering setup again after 4 ish years. I have been using the poly braided hose from lowes. This hose works but gets really stiff in the cold and over time turns rock hard from the oil. I would like to use some rubber hose on the fill nozzle so I can easily move it around in the cold. I bought some farm fuel hose from northern tool to try out but not sure if that will work or not.
Anyone have any suggestions?
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #2 of 5 Old 05-19-2014, 01:44 PM
3/4 HDPE suction hose with the colored helix. I've used the farm hose before, but it goes to he'll also.
vegginpsd is offline
post #3 of 5 Old 05-26-2014, 12:44 PM Thread Starter
tubular031's Avatar
Can you post a link? looks like what I am seeing on a quick Google is wither 1-4 inch or called pvc suction.
post #4 of 5 Old 05-26-2014, 06:17 PM
Yup. With colored helix.
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
post #5 of 5 Old 12-09-2014, 01:03 AM
Cashflo's Avatar
Post
It might be a little late but FYI
Tigerflex is a lot more flexible than pvc at any temp below 120. Its what you see septic truck companies and Yellow Grease collectors like Darling, Brooks, RTI use.
The hose does start to retain some memory in the cold after a few years but NOTHING like the clear suction pvc hose. I will never use that stuff for anything other than permanent install that needs visual of oil.
Move some 150 degree oil in it and most of the memory is gone.
Unless you find a local supplier cheaper, Varco Pumper Supply is the cheapest ive found hose and aluminum camlock fittings. I have come across a deal once in a while on camlocks on Amazon but its rare.
Varco's aluminum camlocks are cheaper than most places banjo or poly fittings.
Tigerflex hose
EPDM Suction and Discharge Hose VARCO
Aluminum camlocks
Punch-Lok Hose Clamps - Small brass fittings - Couplings for industrial applications - International
They do carry a grease and oil compatible hose but its $$ and starts off at 1.5 inch
Varco /-WOR Series Oil-Resistant Corrugated PVC Suction Hose
Then there is this clear polyurethane and its $$$
Bulk OV Series Oil/Grease Suction Hose-Varco /
Handles most fuels and oils. Excellent resistance to gasoline, diesel, ethanol, blends (up to E30) and biodiesels (up to B100).
Only complain I have on camlocks is the edpm seals break down in 6-12 months so buy extras.
They do sell Viton versions but they are just as much or more than the fittings were the edpm seals are $0.20-0.80 each.
I did pickup some 1 inch Viton camlock seals at a great price on Amazon, 50 for $6.50 and free shipping.
Handle every stressful situation like a dog.
If you can't eat it or play with it, just pee on it and walk away.
An Energy-Independent Future~~
Cashflo is offline
