Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Bio-Diesel/Alternative Fuels and Supplements
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
  #31 (permalink)
Old 01-04-2009, 09:12 AM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
Partsgeek.com then search for bosch coolant pump
EDIT: I found the link 1993 Mercedes 300D Auxiliary Water Pump - Cooling System - Bosch - PartsGeek
  #32 (permalink)
Old 01-04-2009, 05:58 PM
tubular031 tubular031 is offline
Thanks clay!
  #33 (permalink)
Old 01-08-2009, 10:59 AM
billman billman is offline
Clay,
So how did you end up wiring it? where did you cut it in? Looks like I may be doing the same thing for my 02 ex.
thanks
  #34 (permalink)
Old 01-08-2009, 11:40 AM
Originally Posted by billman View Post
Clay,
thanks
Wire it to a 12v source that is hot when the ignition is on and i put a switch inline so i can turn it off in the summer time.
I grounded it under the hood right next to the location of the pump.
This pump has some odd looking terminals on it, i happened to have some crimp type connectors in my box of wiring stuff that fit those terminals nicely so once you get the pump, take it to autozone and browse there wiring section for those terminal conectors.
  #35 (permalink)
Old 05-08-2009, 11:16 PM
mankypro mankypro is offline
Now the real trick would be to find this baby in 110v, and plumb it in front of one of these and put it on a timer. Wanna switch to veg faster?
Our electric is still much cheaper than the equivalent in diesel - less than $.05 KWH. Run both for an hour in the morning before you take off for a few cents...
  #36 (permalink)
Old 08-11-2009, 11:05 AM
Put in on a 12 v converter?
